Name this part
Old Jul 12, 2009 | 10:08 PM
MurtazaDSM's Avatar
Default Name this part
What does this connect to?
it is the oild feed line from the turbo I know it goes to the block but what is the name of the fitting it connects to?
Also are these holes suppose to be empty?
Old Jul 13, 2009 | 05:58 AM
MurtazaDSM's Avatar
Default Re: Name this part
bump
Old Jul 13, 2009 | 06:16 AM
kyden's Avatar
the oil pressure sending unit is on that tee fitting.
it looks like that turbo is water cooled. so you have to hook up coolant lines to it.
Old Jul 13, 2009 | 06:26 AM
rip94delsol's Avatar
thats the stock oil pressure sending unit.
If a turbo has 2 ports both are for oil, if a turbo has 4ports it has 2 for water and 2 for oil.
you need an hose ends to hook up to that oil tee to the turbo, most likely a -3 or -4 fitting.
Old Jul 13, 2009 | 10:55 AM
MurtazaDSM's Avatar
where do I hook up the water lines?
Old Jul 13, 2009 | 01:11 PM
LSTEG96's Avatar
throttle body
Old Jul 14, 2009 | 08:31 PM
MurtazaDSM's Avatar
does anyone have any pics of were to hook the lines up, because im not sure were
Old Jul 15, 2009 | 11:15 AM
MurtazaDSM's Avatar
anyone? what throttle body lines do I tap into?
Old Jul 15, 2009 | 12:24 PM
EFbomb's Avatar
the only ones with coolant, on the bottom of the throttle body.
Old Jul 15, 2009 | 05:42 PM
Si GUY99's Avatar
https://honda-tech.com/forums/forced-induction-16/ball-bearing-turbo-coolant-lines-2543099/
https://honda-tech.com/forums/forced-induction-49/turbo-coolant-line-kits-w-black-fittings-2014711/
those should help
Old Jul 17, 2009 | 09:08 AM
MurtazaDSM's Avatar
I think im going to run the turbo with out the coolant/water lines. Can I just bolt them up or can I leave them open
Old Jul 17, 2009 | 07:58 PM
MurtazaDSM's Avatar
anyone?
Old Jul 17, 2009 | 10:03 PM
boostB4beauty's Avatar
IMO, you should NOT run that turbo without using coolant.
It was designed for it, so i wouldn't be surprised if it calved real soon without it's proper application. You just need to plumb it in line with your Throttle Body coolant hose....
Run a coolant hose to your turbo coolant inlet..... and then run the outlet side to the original inlet on the Throttle body...
If that is too hard to figure out, then maybe you better be getting someone to give you a hand with this install. no offence...
Good Luck!!!
97turboteg
Feb 27, 2006 11:34 AM
W O T
Feb 15, 2005 02:50 PM
ross1459
Jun 25, 2003 12:02 AM
jiten42
Jun 9, 2003 07:58 AM
Scott - 93HB Si
Sep 4, 2002 04:14 AM
