View Poll Results: Pick your brand.
Mobil 1
38
31.67%
Pennzoil
5.00%
Castrol
20
16.67%
Royal Purple
21
17.50%
Motul
3.33%
Elf
0%
Amsoil
2.50%
Other (please specify)
28
23.33%
Voters: 120. You may not vote on this poll
What do you run in your setup?
Old Jul 26, 2009 | 09:33 PM
Dubs13's Avatar
Default What do you run in your setup?
I'm assuming you all run synthetic oil in your turbo setups, but what brand?
Old Jul 27, 2009 | 06:55 AM
SilverEk3dr's Avatar
Default Re: What do you run in your setup?
Brad Penn 20-50 (IIRC its not synthetic)
thanks to T1
BlackT5's Avatar
Currently running Motul 8100 5w40 in the Volva
Old Jul 27, 2009 | 07:05 AM
twkdCD595's Avatar
Brad Penn Racing oil here too... their oil is a partial synthetic.
Old Jul 27, 2009 | 12:05 PM
jdm602's Avatar
brad penn 10 40 race here. lean mean and green. lol.
i used to use rp but that ***** 6.99 a quart. now i only pay 5.00 a quart for brad penn by the case at a local shop.
Old Jul 27, 2009 | 01:36 PM
c5R's Avatar
c5R
5w40 rotella T synthetic
Old Jul 27, 2009 | 04:27 PM
TimKennard's Avatar
10w-30 valvoline synpower.
Old Jul 28, 2009 | 04:17 AM
xander1100's Avatar
kendall gt1 10w30
Old Jul 28, 2009 | 09:00 AM
mike_s13_drift's Avatar
castrol 5w30 non-synthetic. would use mobile 1 though if i had to buy my own oil but the castrol is always free where i work
Old Jul 28, 2009 | 12:52 PM
srmofo's Avatar
half of those oils arent true sythetics...they are not using the same base as the others....I got some articles at bookmarked at home, Ill try to remember topost them up later...Theres alot of good articles at bobistheoilguy.com
Old Jul 28, 2009 | 07:19 PM
DC4KiD's Avatar
Castrol.
Old Jul 28, 2009 | 07:57 PM
bigD's Avatar
castrol 5w30 non-synthetic 3 years boosted
Old Jul 28, 2009 | 08:13 PM
1fastlude1's Avatar
val. syn pwr rp is the **** but too expensive
Old Jul 28, 2009 | 10:40 PM
MADMAX_zero's Avatar
The brand doesn't matter.
Just choose the right range to get your oil pressure in check when cold and running hard.
If you don't want to run synthetic, change your oil more often, since non-synthetic breaks down quicker. Synthetic simply allows for longer times between oil changes.
Old Jul 29, 2009 | 07:23 PM
maddog20's Avatar
Old Jul 29, 2009 | 07:26 PM
nuts91civic's Avatar
castrol synn power 10w30
Old Jul 29, 2009 | 08:34 PM
ek9t72's Avatar
val vr1 20w50 haven take the motor apart in 3years first years was around 700whp and the last 2 years 800whp
Old Jul 29, 2009 | 08:55 PM
honda_junk's Avatar
brad penn 20-50 in my turbo gsr
Old Jul 30, 2009 | 07:24 AM
92redhatch's Avatar
I run the cheapest oil I find. 10 40
Old Jul 30, 2009 | 08:29 AM
Dubs13's Avatar
To those running 30 weights in their turbo setups. Have you had any issues with thermal breakdown? That's my biggest issue, my oil breaking down and not getting the proper protection anymore. I'd like to stick to my Mobil 1 10w30 synthetic but I can't help buy think switching to a 40 weight would be better.
Old Jul 30, 2009 | 08:54 AM
eg-gsr423's Avatar
I was running 30 weigh last year and kept toasting it, was changing it every 2 weeks. this year went to vr-1 20-50 well see how that hold up, been 3 weeks and still looks new.
Old Jul 30, 2009 | 09:06 AM
tuan_turbo_dc4's Avatar
brad penn
Old Jul 30, 2009 | 01:27 PM
mrlegoman's Avatar
No.
Plain Castrol 20W-50 changed before and after every track event. Every 3K daily driving.
I did some oil analysis for track driving and it turns out my car could car less what type of oil I run in it. It will break it down in about 150 track miles regardless.
I had a post somewhere....
I'll see if I can find my pdf's of the analysis and do an update.
Old Jul 30, 2009 | 01:36 PM
96 GSR-T's Avatar
I was using RP but that stuff was leaking out of my engine everywhere, switched to Castrol and the leaking stopped.
I will be using either the Brad Penn or Valvoline VR in my new motor.
Old Jul 30, 2009 | 01:47 PM
wrong thread i thought you were talking about motor oil used in a all motor car.
