AEM injector driver install help?
Old Jul 12, 2009 | 08:16 PM
jgrogan's Avatar
Default AEM injector driver install help?
I need some help installing this. What wires do I cut on the factory harness for the injectors. I have the instructions so I know which wires on the aem unit to use but it says very little about which wires for your car. After I cut the wires, one side of the wire goes on the input and the other wire goes to output. The car is a 1998 acura integra. Would be great if someone can help out. Thanks
Old Jul 12, 2009 | 09:13 PM
The sweed's Avatar
Default Re: AEM injector driver install help?
if you cut one wire from the ems u end up with 2 wier ends.. One from the ems and one that goes to the injector or resistorbox. the ones that comes from the ems are "input" cables and the ones that goes to the injectors are the "output" cables then there must be a 12v power cable and a erth cable.. usualy black and red.
Old Jul 13, 2009 | 07:16 PM
jgrogan's Avatar
Anybody know the color wires on the stock harness?
T Dohc
Mar 8, 2006 04:21 PM
White_EK49
Oct 28, 2005 12:15 AM
RTW DC2R
Jul 17, 2005 12:01 PM
1.8turbolsvtec
Nov 10, 2004 02:58 AM
chuckd05
Dec 27, 2001 10:00 PM
