60-1 Power
Old Jul 24, 2009 | 12:06 PM
civic-r11's Avatar
Default 60-1 Power
I have been back in forth about getting a 60-1 turbo.. I am trying to make 600whp on my gsr motor.. The reason why i was thinking about getting the 60-1 one is because they are pretty cheap compared to the other turbo's making that type od power.. what do you guys think about gettting the 60-1? I am not getting into no gt35r's at all.. The only other turbo that i was thinking about was the sc61. what do you guys think that i should do!!The motor that i have is a gsr block with a ls crank and it is sleeved and bored to 85mm. the head is a b16 with skunk2 valvetrain and gsr cams for now.. I am just trying to make 600whp.. the car is not going to be daily driven.. it is just going to be driven when i feel like driving it..
Old Jul 24, 2009 | 12:35 PM
iliv2xlr8's Avatar
Default Re: 60-1 Power
ehh... I would say T67, but I have no experience with a 60-1. You could always go 40R...LOL But yeah, I understand you wanting to save cost.
Old Jul 24, 2009 | 12:41 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
I have a 60-1, good turbo, but I think you'd be pushing it at 600whp...just my opinion
Old Jul 24, 2009 | 12:46 PM
civic-r11's Avatar
that is what i was thinking as well.. so i was thinking about the sc61.. or should i just go bigger...
Old Jul 24, 2009 | 12:48 PM
m R g S r's Avatar
a 60-1 with stage 5 wheel should do 600whp.
Old Jul 24, 2009 | 12:49 PM
civic-r11's Avatar
i mean.. i know that the t3/t67 but i was thinking i could do it with the 60-1 or the sc61. i am kind of lost about this..
Old Jul 24, 2009 | 12:51 PM
civic-r11's Avatar
that is what i was thinking as well.. but i was just seeing what other people setups are before i get mine.. cause i know what will work.. but i want my goal with eithier of these turbo's..
AlphaMike's Avatar
I made about 630hp with a 60-1 on a 84mm GSR, so its very doable.
Old Jul 24, 2009 | 01:09 PM
TheShodan's Avatar
Moderator
Even THAT is pushing it. After 26psi over 2.5 Pressure Ratios, the 60-1 wheel tends to surge a bit. I recommend A GT3540S, or even a Precision6265
civic-r11's Avatar
was that to the wheels.. and which 60-1 did you have.. the specs on the turbo.. i was thinking about getting a different wheel for it.. but i am just thinking about it..
Old Jul 24, 2009 | 01:14 PM
civic-r11's Avatar
the precision 6265 turbo would do it for me.. Cause i was just thinking about going with the t3/t67.. but if i can do it on the precision.. i would get it.. that is what i have been leading towards.
Old Jul 24, 2009 | 01:17 PM
TheShodan's Avatar
Moderator
In order for AlphaMike to come even close to this power, even it would need to be w/ a P-trim exhaust wheel. But again, that has a low probability
Old Jul 24, 2009 | 01:20 PM
civic-r11's Avatar
oh ok.. but that precision would do the job for 600whp.. or should i just go ahead and get the t3/t67 so if i want to run more power i can?
Old Jul 24, 2009 | 01:34 PM
civic-r11's Avatar
Shodan.. are u talking about the billiet turbo's? how are those working for people? aren't those style of turbo's pretty new? who is using these turbo's.. could the chim in..
Old Jul 24, 2009 | 01:43 PM
ScorpionT's Avatar
Ive used the 6262 before. Evos are making 650+whp on them daily without problems. You dont even need the larger 6265, the 6262 will be just fine.
The SC61 will make 600whp without much difficulty, just more boost.
Old Jul 24, 2009 | 02:00 PM
TheShodan's Avatar
Moderator
Evolutions. They like pressure, so they're able to do that power with over 40psi. Meanwhile, and efficient turbo honda will by design be more efficient. The change in exhaust wheel is a few millimeters. He could use either application.
So far, the turbos have been impressive, but not because they use billet materials. That is not what is making them so unique with their power applications. It is because their configurations are done quite well.
Old Jul 24, 2009 | 02:08 PM
ScorpionT's Avatar
True. Ive gone from a 6262 up to a 6265 and it was a bit less responsive and slower spooling. Not a huge difference when running higher HP, but lower boost isnt as much fun.
I cant tell you how many times Ive had to explain to people that its not the material but the compressor design that makes the difference. Ive even had to explain it to guys who dont believe the billet hype, thinking the design is the same and its onbly a different material.
Old Jul 24, 2009 | 02:11 PM
civic-r11's Avatar
Good stuff.. i thought that these were going to be so much money.. and that are only about 850 to 900 bucks.. i could do that.. but i am not sure which one i should get on treadperformance.com or on extreme psi.com.. but i aiming for the 650 one..
Old Jul 24, 2009 | 02:26 PM
85's Avatar
85
Not sure on the price but what about a T61?
Old Jul 24, 2009 | 02:32 PM
single cam fan's Avatar
my buddy is pushing 630 on his built gsr on 28 psi, on his t3 sc61
Old Jul 24, 2009 | 02:35 PM
civic-r11's Avatar
What is his setup?.. and what trim on is his 60-1? Is his 60-1 out of power at 28psi on his motor?
Old Jul 24, 2009 | 02:37 PM
TheShodan's Avatar
Moderator
There is no other "trim" on a 60-1. That is a different wheel than an SC61. Guys. 60-1 does not = SC61. they are not the same turbocharger compressor wheel.
Old Jul 24, 2009 | 02:38 PM
civic-r11's Avatar
that precision billet turbo sounds like the real deal... i don't really see too many people using them, but i would have to say on paper, they are making me think about them because that are making lots of power and it seems to me... and i think that the billiet turbo might spool faster than the t3/t67 turbo that i have been looking at too..
Old Jul 24, 2009 | 02:45 PM
TheShodan's Avatar
Moderator
Hehe. At these sizes, the "spool" difference is not really there either way. It will still come on like a "light switch". A couple hundred rpms give or take. Its amazing how people going for 600+whp look at "spool". We're small displacement engines under 3 litres. It's going to be relatively late in the Honda series engines regardless. I wish people could just accept that small notion.
Old Jul 24, 2009 | 02:47 PM
sanman000719's Avatar
t66 with the S cover is the way i went man, and has seen 650+
