Help. Rod bearing issue
Old Jul 17, 2009 | 04:18 PM
shawn69's Avatar
Default Help. Rod bearing issue
So here is my problem, I was checking all the clearances with plastigage and one rod bearing was too tight, under .001". This was with acl race bearings, so i went to honda and bought the honda red bearings. Still way too tight. The rest were fine about .0015"
b18a
ls crank
eagle rods
arp rod bolts torqued to 43 ftlbs
Any suggestions or ideas on why its too tight?
Old Jul 17, 2009 | 04:31 PM
Transpoquick's Avatar
Default Re: Help. Rod bearing issue
Too tight?, thats better than loose. Polish the bearing surface of the rod and cap + the back of the bearing. Start with 320 grit in your hand(no machines), then buff with a grey or green scotch brite or equivelant. Then re check, I think maybe you have a burr on one of those surfaces cause your real close.
If it is still too tight you will have to get in contact w/ eagle or take the rod to a machine shop and have it reamed.
Old Jul 17, 2009 | 04:55 PM
shawn69's Avatar
I'll give that a try right now.
Old Jul 17, 2009 | 05:09 PM
93supercoupe's Avatar
thats an EXCELLENT idea
Old Jul 17, 2009 | 05:34 PM
shawn69's Avatar
Well has anyone done this before? I wasn't about to use 120 grit that seems a little rough.
I'll assume that's sarcasm so what would you suggest?
Old Jul 18, 2009 | 07:48 AM
I'm sorry, my fault don't use 120, use 320 or higher. Just be gentle. Another option is too have the crank micro polished. Try this first.
5genhatch
Engine Machining & Assembly
May 27, 2019 08:48 AM
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
dj-t
Jul 2, 2009 08:48 AM
pjr710
Aug 18, 2008 11:18 PM
B-B-K
Nov 9, 2005 06:39 PM
