running on 3 cylinders!!
Old Jul 15, 2009 | 04:25 PM
ctr32's Avatar
Default running on 3 cylinders!!
hey guys got a problem.....car is mis firing sounds like a wrx...so i was pullin the spark plug wires off one by one and cylinder number 3 is not running..took off the wire and car didnt not bog down or anything. new wires? rotor and cap? maybe the injectors? i jus switched the injectors to 880cc precision turbo b18 injectors low ohm still kept the resistor box. had 450cc dsm injectors and it did it before too.. need some help fellas
build
agle rods
>> JE pistons(9:1)
>> Port and polished head
>> Feera valves
>> Crowler cams(409)
>> skunk2 cam gears
>> Crowler retainers
>> Crowler springs
>> edelbrock X intake manifold
>> AEM fuel rail
>> AEM fuel regulator
>> Block guard
>> 3"downpipe&exhaust
>> tial38mm wastegate
>> Walboro 255lph HP fuel pump
>> ARP head stud
>> precision 880cc
>> omni 3 bar
Old Jul 15, 2009 | 04:44 PM
jasoncrashtech's Avatar
Default Re: running on 3 cylinders!!
did you check for spark ? did you compression check to see if you have a burnt valve ?
Old Jul 15, 2009 | 05:07 PM
ctr32's Avatar
compression is good....but when i check spark for cylinder number 3!! no spark all the other ones do..i jus pulled the wire off and grounded it on the car somewhere...so now what u u guys think it is before i start to spend cash!
Old Jul 15, 2009 | 05:26 PM
AJxr's Avatar
so its not getting spark on just number 3. try a different wire, take off the distributor cap and look at the peg for the number 3 wire. i wouldnt run it to much aside from just to trouble shoot.
Old Jul 15, 2009 | 05:46 PM
ctr32's Avatar
#1 continuous spark#2 will only spark for a second then stop #3 no spark #4 continuous spark
Old Jul 15, 2009 | 11:04 PM
atom's law doesn't like your number 2 and 3 spark plug wires. i think oem are around 20 bucks a piece.
the stem's could have been separated.
Old Jul 16, 2009 | 05:23 AM
ctr32's Avatar
k Im gonna go to acura today and get new wires! u think the cap and rotor is ok?
Old Jul 16, 2009 | 05:29 AM
malink's Avatar
knock knock
Who's there
maintenance
buy cap, rotor and wires...do it all at the same time
Old Jul 16, 2009 | 05:54 AM
boostB4beauty's Avatar
Originally Posted by malink
knock knock
Who's there
maintenance
^^Agreed...
You spend all that money building a motor up, the least you can do is maintain the ignition system.
Do you change your oil???? hehe just kidding...
but seriously...
Old Jul 16, 2009 | 07:42 AM
ctr32's Avatar
wow chill out there bud
Originally Posted by boostB4beauty
^^Agreed...
but seriously...
Old Jul 21, 2009 | 11:20 PM
mr.nguyen's Avatar
did u figgure it out im running into the same situation new dizzy and plugs and wires
stfuek9
Engine Management and Tuning
Jan 20, 2013 07:25 PM
njmad
Mar 25, 2010 05:35 PM
ctr32
Jun 30, 2009 11:43 PM
spriggan
Jul 18, 2006 09:10 AM
DJone850
Feb 26, 2004 11:34 PM
