Ignition break up after 12psi - ?? - >>
Old Jul 18, 2009 | 08:54 AM
platinum00's Avatar
Default Ignition break up after 12psi - ?? - >>
Typically run 18psi on pump. Been running fine for a few years. Started breaking up around 12-13psi. Feels like misfires which is why I am thinking ignition break up.
Replaced plugs, same results.
What is the next logical problem. dizzy, ignitor, plugs?
thanks
-platinum
Old Jul 18, 2009 | 08:56 AM
locash's Avatar
Default Re: Ignition break up after 12psi - ?? - >>
Check the cap, rotor, and wires. It's always good to have a fresh cap and rotor every so often anyway.. If that doesnt fix the problem, coil and ignitor next. Unless it's possible you put some questionable fuel into it..
Old Jul 18, 2009 | 09:07 AM
1fastlude1's Avatar
i had a simalar problem when id start to build higher boost my headgasket blew between cyl. 2 and 3 it ran fine just driven normal but if i got on it it would miss might check compression, just a thought
Old Jul 18, 2009 | 09:31 AM
tofast4uh22's Avatar
what is the gap on your spark plugs? try gapping them down a little bit.
Old Jul 18, 2009 | 10:20 AM
base-op.1320's Avatar
Check the gap on your pick up in the distributor, I have had same problem in past and tightened gap in distributor and problem went away. I always thought it was a boost issue but it was a rpm issue. For a test you could take your car up to redline without hitting boost and see if it breaks up at all.
Old Jul 18, 2009 | 12:31 PM
platinum00's Avatar
Taking the car to redline (9500) does not break up out of boost. Plug gap is at .028, I typically dont need to go lower unless I run high boost. Do you think I should try .022?
I will look into the cap and rotor. It has been around 6,000 miles since I replaced it. I havent blow a headgaset in a while so wouldnt surprise me. I will check comp and leakdown and report back.
thanks
-platinum
Old Jul 18, 2009 | 09:53 PM
Blaze45's Avatar
Brrraaaap!
Try closing the gap to .22 and see how that works out.
Old Jul 18, 2009 | 10:02 PM
1158's Avatar
thanks
-platinum
My car was doing something similar, but it would only boost to 5 psi when normally it was around 9 psi. The rotor and the inside of the cap were trashed. That would be the first thing I would check.
Old Jul 26, 2009 | 05:51 PM
platinum00's Avatar
I forgot to post the results.
Anyway, cap and rotor let it go to about 14-15psi. After taking the gap to .024 it is back to normal. I think it was a combination of cap, rotor and plugs. They all looked fairly bad.
thanks for the suggestions..
-platinum
Old Jul 26, 2009 | 06:00 PM
ctr32's Avatar
i have just about the same problem mine just wont go pass 4000 rpm's i got new wires and new dizzy will be here monday so i know thats the problem..**** son im from columbus, im taken my hatch to get tuned thursday at slow motion..
-platinum
Old Jul 26, 2009 | 06:31 PM
blackeg's Avatar
tight gap is key in running higher boost/hp on stock ignition system.
i ran .020 gap making 425hp and 18 psi boost on some bkr7e's. never had a problem
axionm1k
Apr 2, 2008 06:58 AM
jdsmooth
Mar 7, 2008 04:59 PM
A.E Motoring
Aug 16, 2006 07:04 PM
89JDMcrx
Sep 9, 2002 11:11 AM
