searched but still not sure on MBC
ok i just bought a cheapo boost controller for now but im still confused on how to run the lines. i have the controller its self with 2 ports then i have a t fitting that says arrow towards wastegate. but my question is do i hook up my blow off valve to it or what i would greatlyt appreciate it if someone had a picture or could give me a diagram of exactly how to hook this up. Thank you.
Re: searched but still not sure on MBC
It goes between your intake manifold and your wastegate. So what ever hose is running to the waste gate, cut, and put the MBC in there, facing the direction noted. make sure the MBC is set to only allow whatever pressure spring in your wastegate, so that you dont over boost first time, and adjust from there
Run 1 line from the boost controller to the turbo. Then run the other line labeled "towards wastegate" to the wastegate. So the boost controller is in the middle of the wastegate and turbo.
there is no a port on my turbo and that still leaves me with another t fitting. i have a tial BOV and a turbonetics wastegate. thanks for the help
DaYZeD.1
03-28-2008 06:54 AM
