Turbo sizing
Old Jul 13, 2009 | 07:42 AM
sleeper_special's Avatar
Default Turbo sizing
I know this question is probably asked 100 times a week but I have tried to read compressor maps and I just cant do it. So I am going to list my setup and hopefully someone will chime in with some expert knowledge of what turbo I will need. I will like to try and keep the car on pump gas and decent street ability since it is a street car. Any help will be appreciated. Also, if the turbo I have is right then what kind of HP do you guys think it will be putting out with my current setup. Just trying to get an idea of what I can make with a tune or do I need to change turbos before sending the money on a tune. Again, thanks for any help.
Electronics:
Greddy type rs boost controller
HKS turbo timer
Hondata S200.
Engine:
2.0 gsr block
AEBS sleeves
Crower rods
JE 84.5mm 9:1 pistons
JE rings
ACL race bearings
Complete ARP bolt and stud kit
micro polished and knife-edge crank
GSR head with stock cams
Skunk 2 cam gears
Full Ferrea valvetrain .5mm over
STR fuel rail
B&M FPR
FP gauge
Precision 1000cc injectors
Venom race intake manifold
Blitz Blow off valve
Spearco FMIC
All t bolt clamps
Love fab top mount mani w/4" down pipe
Complete MSD ignition kit
Urethane mount inserts
LS transmission
Quaife LSD
ACT clutch w\HD pressure plate
GM 3 bar map sensor.
Garrett Turbo (compressor a/r 1.05 turbine a/r .66, I need to do some measurements to determine the actual size)
Exhaust:
Full 3" piping from downpipe
Last edited by sleeper_special; Jul 19, 2009 at 04:28 AM. Reason: had gt45 as turbo size but then was informed that it may be incorrect
Old Jul 13, 2009 | 08:10 AM
TheShodan's Avatar
Moderator
Default Re: Turbo sizing
You've been PM'd..
Old Jul 13, 2009 | 08:13 AM
For some reason its not showing on pm. If you want you can email me at wcollum@live.com
Old Jul 13, 2009 | 10:23 AM
Originally Posted by TheShodan
You've been PM'd..
I never got the pm so I sent you one in return to see if it is the system or what it is.
gixxr7five0
Nov 22, 2010 12:26 PM
ryguy2588
Nov 3, 2010 06:20 AM
aznegg
Jun 25, 2006 07:18 AM
turbodan4
Feb 27, 2006 10:41 AM
domepizzle
Jan 2, 2003 01:18 PM
