optimal motor for FI? as far a bseries builds and tranny combination?
what are the top combinations of motors and tranny for FI
b18b
LSvtec
b18c
b16??
Im finding out that LS tranny is pretty much the best? what are the markings to verify I have found a LS tranny?
thanks guys
b18b
LSvtec
b18c
b16??
thanks guys
Re: optimal motor for FI? as far a bseries builds and tranny combination?
I'd vote S9B LSD box from jdm integra sir/sir-g/uk civic vti hatchback. longer ratios than most B-series box, but not stupidly long and LSD equipped.
sweet thanks any preference on b series motors? I have a ls complete also a 1.8 vtec head and potential moto that is a 16 vtec what would be the best combo?
Are you wanting to boost the motor in stock form or will you be building the block? What are you HP goals?
I will build motor from top to bottom. I am curious to find out what motors require which compression ratios to be a safe motor but put down the numbers relivant to 275-300 and I dotn want to have to run 20 psi to hit this number.. what combinations put down what numbers. looking to purchase a 50min-57max trim garrett or equal. combination of what block and head would most likely get to this number safest, and what ratios on pistions? thanks!
