rubber couplers snapping off and breaking
Old Jul 19, 2009 | 04:26 PM
eg_21's Avatar
Default rubber couplers snapping off and breaking
i got a d16z6 turbo and i keep on breaking and popping my rubber coupler, what do you guys recommend for my next set of couplers, right now i got cheap regular ones with regular clamps i'm planning on getting new clamps and couplers which ones are good for 200-300 whp??
Thanks
Old Jul 19, 2009 | 04:54 PM
Garage 808 Hatch's Avatar
Default Re: rubber couplers snapping off and breaking
get good reinforced silicone couplers and t-bolt clamps. do you have aftermarket motor mounts or mount inserts? it is possible the motor is rocking back and pulling the couplers apart if you do not have them.
Old Jul 19, 2009 | 05:02 PM
SIXTY-1HATCH's Avatar
t bolt clamps are a must!!! Get some triple ply couplings, really strong. What you need to do is bead roll the end of the pipes. Take the piping to someone who can weld, and have them either weld a ring around the ends of the piping, or just have them but 4 tack or beads on each side of the pipe, that way when you bolt your t-bolts on that will serve as a lip and they won't blow off.....
Old Jul 19, 2009 | 05:43 PM
jdm inc's Avatar
Get 3ply couplers and tbolts and like sixty-1hatch said have someone weld or tack up the end of the piping. here a good place to get couplers and clamps http://www.atpturbo.com/Merchant2/me...y_Code=SIL-HMP
Old Jul 19, 2009 | 08:20 PM
eg_21's Avatar
thanks guys i really appreciate all this info, i was already looking into the t clamps, but didn't know which way to go with couplers, that website is really good, those humps in the middle of the coupler should make a difference since that's how my coupler from the elbow of the turbo to the first intercooler pipe looks when it should be flat but after a couple races it would get like that when naturally was flat.
Old Jul 20, 2009 | 08:42 AM
Foowee's Avatar
Do you have stock mounts?
I've never used a t-bolt on any of my setups. They aren't a magic bullet. The hoses with humps may help if your engine is moving while transitioning between loads.
Old Jul 20, 2009 | 11:36 AM
eg_21's Avatar
i got hasport mounts
Old Jul 20, 2009 | 12:21 PM
Foowee's Avatar
Okay so your engine isn't moving... these cheap rubber couplers, are they the ones you get at homedepot in the plumbing section?
Old Jul 20, 2009 | 01:35 PM
eg_21's Avatar
actually home depot was my solution for my throttle body to IC pipe coupler they got this tick as coupler 3'' to 2.5'' my throttle body is was bigger than my piping so i had some getto stuff there to get it from 2.5'' to 2'' but know i'm fine in my with that coupler but i will still order the ones from that website plus t clamps.
Old Jul 20, 2009 | 04:27 PM
My piping would blow EVERY pass @ the track, it was pissing me off. As a matter a fact, I had some cheap couplings and 90's from ebay originally, and I actually blew a hole right threw the 90 deg. one!!! That was only on 16psi, so they are pretty cheap. I had enough and bead rolled my piping, new couplings and t bolts, and I marked where they are when I tighten them and they NEVER budge. You'll be good to go, in the mean time if you spray some hairspray or something of that sort on the ends, then put your couplers on it will dry and stick alittle. We used to do that if we didn't have anything laying around.....
Old Jul 20, 2009 | 04:31 PM
kylea24's Avatar
go to home depot or lowes and get some one is $5 with the t-bolt clamps, i hear they work well just dont use them on the turbo or engine, just on conecting the pipes since there not silicon. if you have 2.5" pipes then you should get 2" couplers at home depot
Old Jul 20, 2009 | 05:58 PM
project dc2's Avatar
oh jesus. GET REAL COUPLERS
dont get no home depot crap, those things expand and crack and heat up and expand and slip off.
stop doin ghetto stuff to your car and it wont come off so often
Old Jul 21, 2009 | 07:35 AM
90blackcrx's Avatar
We have some in stock, and we are local to you.
Old Jul 21, 2009 | 08:48 AM
Boostfed86's Avatar
Reinforced Tractor Trailer radiator hose works wonders... Its hella thick and some dealers even use a Chop Saw to cut it. I've used it quite a few times when in a Bind. Run a small bead of silicon around the pipe when you slip the coupler on also and get some T-clamps!
killacam661
Nov 24, 2008 10:46 PM
LilCivic04
Apr 22, 2005 08:07 PM
420aNT
Mar 1, 2003 06:22 AM
C-Murdock
Feb 15, 2003 06:05 PM
