Is running an open turbo bad?
Old Jul 15, 2009 | 04:50 PM
85_305's Avatar
Default Is running an open turbo bad?
I'm using a master power t70 turbo and there isn't a filter on it. Is this bad?
What kind of filter should be put on it IF this is a bad situation?
Old Jul 15, 2009 | 06:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Is running an open turbo bad?
Is it a daily driver? Think about it... sure it’s bad. You are sucking in anything that gets on your front bumper, windshield, ect. Dirt, bugs, water, you name it, and it could get into your motor. Best case scenario it is just scarring up with inside of the compressor housing or pitting the blades. To each his own though, I live where there is a lot more dust, maybe you don't see it where you live, IDK. If you wouldn't put your head outside the window and open your mouth to breathe in whatever is coming at you, then you should do the same for your turbo/motor.
Old Jul 15, 2009 | 06:39 PM
Schister66's Avatar
Man U FTW
I've always run a piece of metal screening doubled over held down with a worm-style clamp. Sounds ghetto, but space is an issue
Old Jul 15, 2009 | 06:43 PM
NLR808's Avatar
pffft the blades in the turbo act like a blender...... till they meet a rock i do what schister does
Old Jul 15, 2009 | 07:41 PM
jhammond_82's Avatar
Reject Papi
you eat up a bird you'll know if its a bad situation or not.
Old Jul 15, 2009 | 07:45 PM
solo227's Avatar
Streetcar- YES
Racecar- NO
Old Jul 15, 2009 | 09:26 PM
tek_civic's Avatar
Get a filter or put a video camera in your engine bay always recording. I want to see that vid on youtube when something gets sucked in.
More than likely it will just be increased wear from dust constantly going in and acting like sand paper all over your engine and turbo.
Old Jul 15, 2009 | 09:39 PM
Reject Papi
hmm....i never thought of it like that before. good point.
Old Jul 16, 2009 | 12:24 AM
redtegra's Avatar
ever see a stock car with no air filter??? or even a fully built n/a car with no air filter?? either have i.
Old Jul 16, 2009 | 07:32 AM
85_305's Avatar
Good input. Thanks guys.
turbo gsr2000
Feb 11, 2010 05:05 PM
cleansi
Nov 10, 2009 10:55 PM
scspeed
Apr 28, 2008 01:14 PM
StolenTeg
Jul 26, 2004 08:00 AM
pagong
Feb 15, 2003 09:59 PM
