need a datasheet for honda map snes.
Old Jul 26, 2009 | 08:23 PM
runsfromdacops's Avatar
Default need a datasheet for honda map snes.
have a honda firewall map (denso pn:079800-1771 5v, ps-20) i need the exact voltage per psi of boost. i have looked for hours and have found nothing.yes i know i can use all sorts of other sensors but i have this one and it is free.
thanks guys
Old Jul 27, 2009 | 12:24 AM
HiProfile's Avatar
Default Re: need a datasheet for honda map snes.
Honda has loved the 1.75bar for many of their cars. The only difference seems to be the max/min readable pressures due to the design. Do you know what chassis it comes from?
Feed it 5 volts in free air, measure the output voltage, and if it's like a regular 92-00 TB sensor (1.75bar, ~2.8v) then it's a 1.75bar. Otherwise extrapolate with a linear line, with -14.5psi falling around 0.1v, and the max falling around 4.8v or 4.9v.
Pray tell, why do you need the exact voltages? Most tunes will be different enough where a rough basemap will need heavy adjustments anyways.
Old Jul 27, 2009 | 12:34 PM
omniman's Avatar
thanks guys
how much is time worth?
human life expectancy is 78 years, how much of it will you waste?
Old Jul 28, 2009 | 11:19 AM
Its for my turbo bike. And its only going to run around 10-12 psi of boost so I don't really see the need to use a gm 3 bar for 100$ just becuz the info is esayer to find.I have more time them $$ and I didn't really think it would be this hard to find
Old Jul 28, 2009 | 12:58 PM
93turbo16's Avatar
It is linear so just plot it out.
http://wikitest.pgmfi.org/twiki/bin/...rary/MapSensor
GoLowDrew
Apr 8, 2011 05:26 AM
runsfromdacops
Jul 26, 2009 08:21 PM
B16Civic93
Apr 2, 2005 09:39 AM
turbohf
Dec 21, 2002 07:11 PM
