CXRacing or SPFab 1/2 Size Radiator
Im going for about 300 HP on my B18B-Turbo Integra and need a radiator on a budget. I found these two manufacturers and was wondering if anyone has any experience with them. Pictures would be great too, I am wondering if my stock hoses and fan will work on either of these, and how I would mount them (on an Integra).
Also, the inlet is 1.25" (Cxracing) Vs. 1" (SPFAB)
CXRacing
http://www.cxracing.com/mm5/merchant...gory_Code=RADI
SPFAB
https://honda-tech.com/forums/showth...light=radiator
Thanks!
CXRacing
SPFAB
Thanks!
Re: CXRacing or SPFab 1/2 Size Radiator
either should work just fine. spoolin is an H-T sponsor and very reputable. either way you will mostly likely need to run a slim fan as the turbo setup will not allow room for oem fan and shroud
