oil pan question
Old Jul 18, 2009 | 10:58 PM
MurtazaDSM's Avatar
Default oil pan question
I have this on my drain line from the turbo
can I use this piece on the oil pan to connect it
http://cgi.ebay.com/ebaymotors/Summi...Q5fAccessories
Old Jul 18, 2009 | 11:42 PM
cbustuner's Avatar
Default Re: oil pan question
Yes if your line is -12 and it's using a -12female end fitting. If it isn't you can use something like that just in a different size. I used a similar fitting on my first ever turbo kit.didn't really like it (had trouble with the locknut on the fitting coming loose when you would try and undo the line) but it works if you can't weld
Herro Panda
Aug 15, 2012 05:31 PM
MalcolmV8
Dec 5, 2011 05:29 PM
MrDomino
Jul 7, 2010 08:30 AM
labtec
May 3, 2007 10:53 AM
toolowsol
Feb 9, 2006 01:52 PM
