new build, before starting
Old Jul 24, 2009 | 08:00 PM
acc98ord's Avatar
Default new build, before starting
Hopefully will get my h22 block back from sleeving and complete build soon.
Are there any prereqs that are required before bolting on the head and first startup?, As far as the rings and cylinder walls on first startup? Thanks in advance.
In the mean time I will keep searching for build tips.
Old Jul 25, 2009 | 05:33 AM
jsbayer's Avatar
Default Re: new build, before starting
Can you elaborate on your question? If your getting your shortblock back from machining, it will be cleaned and trued. get a new head gasket, and bolts, and put it back together. break in the engine (how ever the machinist told you to)
Old Jul 25, 2009 | 07:33 PM
acc98ord's Avatar
Well I understand that it was a rather general question. I have never put an engine back together with brand new parts. It kinda sounds silly but, Is there any lube or anything to put on the cylinder walls or camshafts before first startup? I will be using the Helms manual for EVERYTHING besides all the work that has been done as far as bearings, rods, rings, valves. You're right this should probably be directed more at my builder/machinist. Thanks again!
jesse0880
Dec 11, 2009 01:55 PM
SmoothCTR
10
Nov 30, 2009 10:56 AM
rossfashow
Apr 30, 2009 11:40 PM
Vbp6us
Mar 13, 2005 07:48 PM
Cashflo
Jan 22, 2003 10:06 AM
