Shogun Power tuner?
Old Oct 20, 2001 | 07:27 PM
LsTurbo91's Avatar
Default Shogun Power tuner?
Is this for real? seems really cheap? and only for $500.
Here's a quote from groupbuy:
Whether you're on the street or the strip, turn you import into
a "warrior" with the Shogun Power Tuner. Hypertech's Shogun Power Tuner allows
you to optimize the ignition timing and air/fuel ratio for stock or modified
Japanese imports... at the touch of a button. Allows you to re-tune for maximum
power over the entire RPM band and raise the rev limiter for maximum performance.
Installation is quick and easy...no cutting into the wiring harness. Just
plug the Shogun adapter between the stock computer and the stock wiring harness.
Whether you install a turbocharger kit, nitrous system, exhaust header, camshaft,
or any other popular speed equipment, The Shogun Power Tuner is the only
custom-tuning, emissions-legal, programming product available for popular
Japanese import vehicles, at an affordable price.
FEATURES:
Rev Limiter Adjustable In 500 RPM Increments
Air/Fuel Ratio Adjustable In +/-2% Increments
Ignition Timing Adjustable +/-1 Degree Increments
Upgradeable For Tuning With Nitrous Oxide, Turbocharger or
Supercharger
Controller Displays "Live Time" RPM, Ignition, And Fuel Data While
Driving
Easy Installation
50 State Legal
Old Oct 21, 2001 | 10:50 AM
SiR Kid's Avatar
New User
Default Re: Shogun Power tuner? (LsTurbo91)
I had one and we tuned it on my B16a n/a with ITR cams, ITR manifold, JG TB, no fuel pressure regulator, and stock cam timing... Stock header and a k&N on the TB, how much would I have gained y'think from an AEM and a good header?
Pick up 15ish HP from the time we first put it on the dyno.. PLUS got rid of my JDM ECU's speed cut. The thing I loved was the THROATY well fed sound the engine made after tuning!! AWESOME!
As you can tell from the dyno below... my power was only hindered by stock valve float issues.... I WISH I'da had my ITR springs in at that time... Would have been nice to see 9k rpm and 160 at the wheels on a stock engine
They are for real.
[Modified by SiR Kid, 7:56 PM 10/21/2001]
Old Oct 21, 2001 | 11:06 AM
1.8EG-T's Avatar
Has anyone used it on a FI vehicle, namely turbo? Anyone.
Old Oct 21, 2001 | 11:28 AM
chri5's Avatar
Default Re: Shogun Power tuner? (hybridrex)
my freind has one in hs SC LS teg. He likes it. I'll try and get a more detailed opinion fom him to post.
Old Oct 21, 2001 | 11:32 AM
AshlandSi's Avatar
Default Re: Shogun Power tuner? (Chris_Turbo)
Is it splice or plug-n-play?
Old Oct 21, 2001 | 11:59 AM
1.8EG-T's Avatar
From what I have read, you plug it in between the ecu and the harness.
k_lude
Sep 29, 2008 11:03 PM
falcongsr
Aug 8, 2002 12:51 PM
FuzzyGreen
Feb 26, 2002 12:14 PM
