Woohoo!...block's back.
Old Oct 18, 2001 | 09:23 PM
clendaniel's Avatar
Default Woohoo!...block's back.
Got home from work to find that my block had finally returned from Golden Eagle...attached some pics below.
Sleeves are beefy as hell...gonna take it to a local shop tomorrow to see about honing. I was a little disappointed as they f*cked up and did a step-deck and not o-rings. I called them to complain about it and they offered to reimburse me for the cost to o-ring locally...I was impressed. But it raises a question...will the step-deck (sleeves are raised .001" above the deck) be sufficient for my use, a street-driver running approx 1.4-1.5bar?? Anyone have experience running that setup?
--Ian
Old Oct 18, 2001 | 09:25 PM
Blown90hatcH's Avatar
Default Re: Woohoo!...block's back. (clendaniel)
What size sleeves are those?
Old Oct 18, 2001 | 09:26 PM
clendaniel's Avatar
Default Re: Woohoo!...block's back. (Blown90hatcH)
stock bore...87mm
--Ian
Old Oct 18, 2001 | 09:31 PM
dustin's Avatar
That is absolutely beautiful. A tear forms.
Dustin
Old Oct 18, 2001 | 09:32 PM
Mikex25's Avatar
New User
How long did it take you to get your block back?
Old Oct 18, 2001 | 09:35 PM
clendaniel's Avatar
Default Re: Woohoo!...block's back. (Mikex25)
5 weeks total...1wk shipping each way and they had it for 3.
Now to finish up some minor machine work and get the thing back together!
--Ian
Old Oct 18, 2001 | 09:38 PM
Mikex25's Avatar
New User
Good thing they didn't lag that much like most other shops, how much you planning to boost on that motor?
Old Oct 18, 2001 | 09:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
I think Beefy is an understatement..
art
Old Oct 18, 2001 | 09:45 PM
VaporTrail's Avatar
New User
make sure you price o ringing locally....I found it to be 150, and they offered to reimburse 30, so I just sent it back on their tab. Vince kicks butt
Old Oct 18, 2001 | 09:57 PM
InfamousRS's Avatar
Default Re: Woohoo!...block's back. (VaporTrail)
how much did that cost you. Do Dartons compait to those, just curious?
[Modified by BLK94RS, 7:02 AM 10/19/2001]
Old Oct 18, 2001 | 10:15 PM
954DR's Avatar
New User
Old Oct 18, 2001 | 10:19 PM
AshlandSi's Avatar
Default Re: Woohoo!...block's back. (954DR)
Damn, you sleeved a H22?
How much power are you aiming for?
400whp?
Old Oct 18, 2001 | 10:41 PM
VaporTrail's Avatar
New User
Default Re: Woohoo!...block's back. (BLK94RS)
more streetable than Darton's, IMHO. Still keeps the open jackets, yet incredibly strong.
here's mine, though it's not done yet
Old Oct 18, 2001 | 10:56 PM
G_Man604's Avatar
if u ain't using it right now..spray some wd-40's so the sleeves won't rust
Old Oct 18, 2001 | 11:05 PM
dustin's Avatar
Default Re: Woohoo!...block's back. (G_Man604)
Yeah or just any grease will do it.
Old Oct 19, 2001 | 09:48 AM
clendaniel's Avatar
heh...yup already oiled up. I was surprised that when I opened it up that it was bone dry.
Just ordered the rest of my bearings (my dumb *** didn't write down the crank journal codes before I shipped it). Taking the block in Monday and my machine shop is honing it, high-speed balancing the crank and doublechecking the rods/pistons (JE 9:1's and Pauter X-beams). Hopefully by next weekend I'll have everything in hand to start assembly.
I take it the consensus is to get it oringed and screw the step deck??!?
--Ian
Old Oct 19, 2001 | 09:55 AM
DirtyLude's Avatar
Man, I really like those sleeves and the upper brace. I wish I could've sent to them, but the shipping from Canada just wasn't worth it. My own shop is putting in sleeves they made, which are t-top similar to the Darton sleeves. I should have pictures tonight.
Old Oct 19, 2001 | 10:05 AM
shingles's Avatar
Can I ask a beginners question: what's o-ringing?
thanks!
-Shing
Old Oct 19, 2001 | 10:53 AM
VaporTrail's Avatar
New User
Default Re: Woohoo!...block's back. (shingles)
O ringing is the process where a small groove is cut, outlining the top of the cylinder sleeves where the headgasket lays. In this small groove, a small strip of copper is pressed in, and protrudes slightly up. This allows the head gasket to seal even tighter. HTH
Old Oct 19, 2001 | 11:11 AM
rtype11's Avatar
I have a different concept of O - ringing, v - shaped grooves are cut around the head as mentioned above and then SS aircraft wire is pressed into the groove not copper, this combined with a copper head gasket is an unblowable seal. generally 0.043 ss 314 wire.
cheers,
Old Oct 19, 2001 | 12:36 PM
VaporTrail's Avatar
New User
Default Re: Woohoo!...block's back. (rtype11)
well I was speaking for use with tri metal (oem honda) head gaskets, no copper ones (bleh!).
Old Oct 19, 2001 | 12:45 PM
b18bturbo's Avatar
copper just takes so much effor to seal correctly. Compared to just factory gasket. I havent seen to many factory gaksest just plain melt.
B16A1-EF9
Sep 23, 2004 05:06 AM
DC2R714
Jul 8, 2003 03:38 PM
qqqq
Apr 30, 2003 03:42 PM
TurbodCX
18
Dec 30, 2002 07:08 AM
SOHC_DK.
Dec 28, 2002 01:31 PM
