Need Help with adjusting GReddy Type S BOV Soft? Hard?
How is GReddy type S suppossed to be set/adjusted? I'm running from 8 to 11psi, but I dont know the Proper way of adjusting the blow off valve and the differences between soft and hard...
any help would be greatly appreaciated.
Someone told me today you just adjust it for sound, that "Hard" pops more with louder whistle, but that it makes no performance difference...that sounds hard to believe...
So whats the truth?
So whats the truth?
Re: Need Help with adjusting GReddy Type S BOV Soft? Hard? (greyzone)
You dont want it too hard because you will have compressor surge. Just have it soft enough so it wont open up during boost. Again, dont adjust it too hard.
art
art
Re: Need Help with adjusting GReddy Type S BOV Soft? Hard? (Arturbo)
So how do I know when its set too hard?
What is compressor surge and how do i tell if thats occuring?
How do i know if its set too soft?
Im seriously asking these questions, i dont know this stuff.
I guess Im looking for HOW am i suppossed to set it and WHEN do I know its just right, not too soft, not too hard?
[Modified by greyzone, 8:54 AM 10/19/2001]
Adjust it to the softest setting, then adjust it to at least 5 full turns. It should be ok there. Do you know to adjust it?
art
art
DOnt I back off the locking nut and then turn the threaded stud?
Adjusting to the softest position, that should be all the way counterclockwise? And I think clockwise, or in is HARD.
But if I back it out, will it stop or come all the way out?
You are correct on how to adjust it. Dont take it out all the way. Just back it out some and then go from there. I didnt have to adjust it very much when it came from Greddy. But I did make it soft just to be safe.
art
art
Re: Need Help with adjusting GReddy Type S BOV Soft? Hard? (Rob92SC)
Another thing im wondering is i keep having to turn up my boost controller (GReddy ProfecB) to keep the same level of boost, now, with it turned all the way up (Hi Boost) it wont even go to 10psi, and it used to be at 11psi turned all the way down...
what gives? could the BOV be bleeding off pressure so the boost is not building up? Or is the boost controller taking a ****?
aaarrrrrrgggggggggggg...
let me know what you think
AGAIN, SO HOW DO I KNOW WHEN IT IS SET TOO HARD OR TOO SOFT?
What are the symptoms of each, at this point i still dont know how to adjust it and be aboe to tell if its right or wrong, and what signifies right and what tells me its too hard and that im risking compressor surge...
I NEED HELP ON THIS ONE PLEASE
