NEED BOV HELP!
Old Oct 21, 2001 | 01:14 PM
Mr. Vapor's Avatar
Default NEED BOV HELP!
Ok, i am on the LAST part of my ******* install, and i cant get my damn BOV on...the HKS SS......its got that snap ring, and ive been working for an hour and a half trying to get the damn thing on my pipe, but i cant do it, does anyone have any tips, hints, what tools they used anything, i am getting very discouraged....please guys!
Old Oct 21, 2001 | 01:31 PM
udctown's Avatar
New User
Default Re: NEED BOV HELP! (NYb16)
hey nyb16,
i just put it on yesterday. i wasn't getting anywhere until someone told me to use c clip pliers. they are the only way to do it. if you see the two holes at the ends of the c clips. that is where those pliers hook up to. it is still hard so make sure you have a buddy. squeeze with the pliers and try to get them under the lip and have a buddy with a screwdrive on the other side pushing the clip in.
good luck
Old Oct 21, 2001 | 01:43 PM
Mr. Vapor's Avatar
Default Re: NEED BOV HELP! (udctown)
yea i got the C-clip pliars, they have the little pins in the ends.......but which end did you put in first etc?
Old Oct 21, 2001 | 02:42 PM
dustin's Avatar
All the c clip pliers I could find were cheap as a mother truck.
I ended up buying some really narrow needle nose pliers at home depot. I bent them all around with a vice until I had an "HKS SS Bov C clip installation tool". We have installed 2 BOVs with it now, works pretty well
Dustin
Old Oct 21, 2001 | 02:43 PM
Mr. Vapor's Avatar
Default Re: NEED BOV HELP! (dustin)
so you just bent them to 90' angles and used that?
Old Oct 21, 2001 | 03:28 PM
Joe's Avatar
Joe
I bent it at a 45 degree angle near the tips, and then I bent in each of the tips so they would 'hook' the holes on the c clip.
Dustin (posting as Joe)
Old Oct 21, 2001 | 04:23 PM
udctown's Avatar
New User
the c clip plier i used were already bent at 90 degree angles on the tips. just start squeezing with the pliers and put the plier side under the lip as much as you can remember to keep pressure so that the plier don't slip out (was a problem for me) and then have the friend put the opposite side under the lip with a screwdriver.
Old Oct 22, 2001 | 08:29 AM
Mr. Vapor's Avatar
i got it guys, thanks for the help
Old Oct 22, 2001 | 03:48 PM
Ri5e's Avatar
I couldn't get mine in. I snapped the C-RING some how? So I zip tied the BOV to the pipe. Hey...it works.
HybridKOOP
Jul 27, 2002 12:34 AM
Total'd GSR
Apr 25, 2002 06:53 AM
JMinSi2000
Mar 28, 2002 09:25 AM
TurboSedan
Feb 10, 2002 08:03 PM
Ri5e
Oct 22, 2001 04:32 PM
