Map sensor
Old Oct 20, 2001 | 07:32 PM
joeyitr309's Avatar
New User
Default Map sensor
Where can I get a map sensor that will read more than 12psi and is a simple bolt on affair for a b18c5.
Old Oct 20, 2001 | 07:35 PM
LsTurbo91's Avatar
Default Re: Map sensor (joeyitr309)
I think you need a stand alone to compensate for a GM 2/3 bar map sensor. Essentially you will need a 2 bar map sensor good up to 15psi.
Old Oct 20, 2001 | 07:36 PM
joeyitr309's Avatar
New User
Default Re: Map sensor (LsTurbo91)
I have a power fc
Old Oct 21, 2001 | 06:24 AM
TurboSedan's Avatar
New User
Get the GM 3 bar MAP sensor dude. They have a page about it on Hondata's site.
Old Oct 21, 2001 | 12:04 PM
boosted3g's Avatar
Default Re: Map sensor (97CivicFerio)
You can use a GM sensor with the Power FC but the maps will be way wrong so you will have to move them. For instance on the stock map when your car is turned off and there is no vacuum and no boost it should read near 2.85 volts but with a 3 bar sensor it is way different so the if you moniter with the map tracer on the FC you will notice that it is way off. I forget how far off but it is different but the GM sensors will work on the Power FC.
young geezer
Aug 1, 2009 12:44 PM
EJ8 GSR-T
Mar 29, 2007 06:48 PM
turbolshatch
Feb 2, 2006 06:06 AM
turbotypeR@SPEC
Jan 9, 2002 04:29 AM
