drag 3 is installed!!!!
Old Oct 22, 2001 | 04:51 PM
udctown's Avatar
New User
Default drag 3 is installed!!!!
well i got everything installed and i am picking my car up tomorrow. i dropped it off at a auto shop to have a new exhaust put in.
here is a question though. i have driven it twice and have hit boost once to test it. (i want a new exhaust before i really start to test it. ) well anyways when i open my hood there is a small wisp of white smoke coming from around the manifold. i can't specifically locate the source and my question is....is this just breaking in the turbo as it's burning off stuff or should i just check all my oil lines going in and out of the turbo.
thanks guys for everyhting.
Old Oct 22, 2001 | 04:54 PM
DragII's Avatar
25 Year Member
Default Re: drag 3 is installed!!!! (udctown)
the smoke is normal
congrats on the install
Old Oct 22, 2001 | 04:57 PM
HX_Guy's Avatar
Default Re: drag 3 is installed!!!! (DragIIcivic)
Id guess its just dirt/oil burning off the motor/manifold/turbo since your hands were dirty when installing it. Happens to me whenever I instal something
Old Oct 22, 2001 | 05:19 PM
DragII's Avatar
25 Year Member
Default Re: drag 3 is installed!!!! (HX_Guy)
its the coating on the manifold....it will burn off and soon yours will be rust covered like the rest of our
Anthony K's Avatar
New User
Same thing happend to me. It's normal.
Old Oct 22, 2001 | 06:19 PM
InfamousRS's Avatar
Default Re: drag 3 is installed!!!! (Anthony K new boost junky)
Can you have the manifold coated with anything so it will not rust and still look good?
Old Oct 22, 2001 | 06:45 PM
GSR_Dude's Avatar
Default Re: drag 3 is installed!!!! (BLK94RS)
I used VHT high temp paint. Not sure how long it'll last and I know it's going to burn off, but at least it's better than nothing.
Old Oct 22, 2001 | 07:26 PM
Smashback's Avatar
YES, you can have it ceramic coated. Shouldn't cost much, maybe $100? Looks GOOD and lasts a long time.
Old Oct 22, 2001 | 07:49 PM
InfamousRS's Avatar
Default Re: drag 3 is installed!!!! (mplex2000)
where can you send it to have it ceramic coated???
Old Oct 22, 2001 | 08:04 PM
Integra187's Avatar
im kind of new to turbo kits, but arent you always boosting when u have the kit or u just push a button to start boost. thanks.
Old Oct 22, 2001 | 08:28 PM
ken's Avatar
ken
Default Re: drag 3 is installed!!!! (Integra187)
With a turbo, you are boosting when the turbo spools up... normally around 3k rpm, but it varies.
Supercharges are boosting all the time.
And nitrous involves the pushing of a button... in most setups.
Old Oct 22, 2001 | 08:42 PM
Blown90hatcH's Avatar
Default Re: drag 3 is installed!!!! (SeaDawg)
You can have it ceramic coated.....check it out. I think it looks sweet too...
Old Oct 22, 2001 | 09:50 PM
b18c5hatch's Avatar
New User
Default Re: drag 3 is installed!!!! (Blown90hatcH)
where did u get that done, looks good!! and what did it cosy u??
Old Oct 22, 2001 | 10:05 PM
LsTurbo91's Avatar
Default Re: drag 3 is installed!!!! (b18c5hatch)
yea, where and how much?
Old Oct 23, 2001 | 03:15 AM
Zeus's Avatar
...and more importantly, the coating helps keep the underhood temps down...
Old Oct 23, 2001 | 04:19 AM
Ubermensch's Avatar
Default Re: drag 3 is installed!!!! (Zeus)
Yes, and it helps keep the thermal energy in your exhaust gas flow, but doesn't it shorten the life of the manifold due to the increased heat in the metal?
Old Oct 23, 2001 | 04:32 AM
boomslang's Avatar
Default Re: drag 3 is installed!!!! (Ubermensch)
No. If done properly, it will be coated inside and out. The coating on the inside keeps the heat out of the manifold.
That heat wrap tape stuff will shorten the life of a manifold because it's on the outside of the manifold. The heat will go into the manifold and be kept in by the tape.
Old Oct 23, 2001 | 08:24 AM
Ricehornet's Avatar
is that jetcoating thing posted a while ago a ceramic coat also or is it different?
I forgot who had it done, but it was to a ITR header if i remember correctly.
Also, coating and retaining heat pre-turbine is a very good thing...more energy going in and not escaping.Thus if things go right, and the exhaust is cool, lots of energy tranferred to work on the shaft spinning the compessor. .Efficiency is a good thing.
Old Oct 23, 2001 | 10:48 AM
Del's Avatar
Del
Default Re: drag 3 is installed!!!! (Ricehornet)
What kinda manifold is that it looks good?
2000civic ex
Apr 1, 2008 02:29 AM
integrx
Jan 24, 2004 09:33 PM
jaymes2030
Jan 17, 2004 08:20 PM
alfee
Oct 14, 2003 07:02 PM
KevronsEG
Aug 25, 2002 03:58 PM
