homade boost controller 10psi?
Old Oct 18, 2001 | 07:46 AM
clean's Avatar
New User
Default homade boost controller 10psi?
i put a homemade boost controller on my turbo yesterday and tried to set it. it's hard dialing in 8pi, thats what i was told would be safe on my d series w/ stock internals. it's around 9 and dont hear any pinging from detonation. has anyone uesd a homemade boost controller? how bout w/ the greddy kit on a 6th gen?
Old Oct 18, 2001 | 10:40 AM
clean's Avatar
New User
Default Re: homade boost controller 10psi? (clean)
really
Old Oct 18, 2001 | 10:44 AM
dbman96's Avatar
New User
What does your car boost to WITHOUT the boost controller? Your boost controller only allows you to increase boost, you can't decrease it from wherever the wastegate normally opens. Even if your wastegate is hypothetically set at 8 psi it may take an extra bit of pressure to open the check valve in a manual boost controller and make it so you can't set it lower than 9 psi. You probably need a lighter spring in your wastegate.
Old Oct 18, 2001 | 10:48 AM
clean's Avatar
New User
Default Re: homade boost controller 10psi? (dbman96)
no it's all good, the wastegate is set @5.5 psi and all i wanted to know is if i was safe running @ 9 with the greddy kit. thats all. i made the controller out of a male and female nipples, spring and ball bearing from the hardware store. some people i hear use check valves from the fish store
VTC_CiViC's Avatar
I have a GReddy in my 98 EX, I also had a manual controller. Biggest POS I ever used in my life. Damn thing would always drop the boost whenever it wanted too, most inaccurate peice of garbage I ever used. Thank god I went with an EBC!
Old Oct 18, 2001 | 11:08 AM
Rob03Pro5's Avatar
i made the controller out of a male and female nipples...
That is just SICK! Hehe.. Maybe you need to change the strength on the spring to make it go lower than 9psi.
Old Oct 18, 2001 | 11:16 AM
VTC_CiViC's Avatar
Default Re: homade boost controller 10psi? (Rob92SC)
Just cut off one of the coils on the spring.
BlUAc
May 20, 2006 09:43 AM
c61lude
Jan 19, 2006 04:34 PM
stockgreencivic
Apr 10, 2003 07:32 PM
Snafu-Si
Mar 5, 2002 02:07 AM
accordfreak
Dec 25, 2001 12:20 AM
