255 intank or the inline that..
Old Oct 17, 2001 | 08:52 PM
BoostinDC2's Avatar
Default 255 intank or the inline that..
255 intank or the inline one that drag gives you???? which pump?
Old Oct 17, 2001 | 08:55 PM
Mikex25's Avatar
New User
Default Re: 255 intank or the inline that.. (BoostinDC2)
if you don't have a engine management you have to get a inline. Only a inline pump can handle all the high fuel pressures that the FMU set up gives you. I would say go with either a bosch or a nose one those are the only ones that can handle really high pressures. If you have a stand alone go with a walbro intank.
[Modified by Mikex25, 6:25 AM 10/18/2001]
Old Oct 17, 2001 | 08:57 PM
BoostinDC2's Avatar
Default Re: 255 intank or the inline that.. (Mikex25)
yeah i have the power fc. im about to get my car tuned and want to know if i should switch to intank.
Old Oct 17, 2001 | 09:01 PM
DC2's Avatar
DC2
Jerry,
If you can, try to get yourself a Supra TT OEM pump. These things are badass. They flow enough to support your setup. Check out this link. http://www.3si.org/member-home/jluci...lpumpguide.htm
Old Oct 17, 2001 | 09:13 PM
BoostinDC2's Avatar
Default Re: 255 intank or the inline that.. (DC2)
thanks Chris. do i know you from some where?
Old Oct 17, 2001 | 09:26 PM
Mikex25's Avatar
New User
I would say either get that or a Walbro intank.
Old Oct 18, 2001 | 12:35 AM
greyzone's Avatar
"if you don't have a engine management you have to get a inline. Only a inline pump can handle all the high fuel pressures that the FMU set up gives you."
uh, Mikex25 thats not correct.
In tank pumps work fine and can pump out the required pressure, such as the holly 255 in tank. Also, in tank will be considerably quieter, which can be a real plus as the whine of the in line can get down right irritating.
[Modified by greyzone, 9:40 AM 10/18/2001]
Old Oct 18, 2001 | 06:01 AM
VTC_CiViC's Avatar
This is true only if you're going with a high presure FMU style setup. If you go with a large injectors setup, and use an AFC to trim it, an intank or even your stock pump is fine since your pressures are near stock.
[Modified by VTC_CiViC, 10:02 AM 10/18/2001]
Old Oct 18, 2001 | 06:47 AM
integRated109's Avatar
Default Re: 255 intank or the inline that.. (VTC_CiViC)
i have a holley in tank, and until my injectors get here im still running the 12:1 in the fmu. i had the inline until the wire came loose one time, and my car backfired like a damn machine gun soon as i hit boost....scared the hell out of me, so i ordered the in-tank the next day. seems to run really great, but that holley gets noisy if it gets too hot...REALLY noisy.
Old Oct 18, 2001 | 07:17 AM
VTC_CiViC's Avatar
Default Re: 255 intank or the inline that.. (integRated109)
I know what you mean, anybody standing outside my Civic with the Walbro pumping away would swear they're standing next to a plane.
Old Oct 18, 2001 | 07:31 AM
gs-turbo's Avatar
New User
That's no joke either....walbro hums like a *****........whinning away....esp when you first start the car......I feel like turning around, and telling it to STFU sometimes...ohh-well...
kpjo4
Jun 4, 2010 05:19 AM
Blue-EM1
Jun 23, 2005 08:26 PM
R-1303
Jul 11, 2002 04:15 PM
DeeJay
Oct 31, 2001 09:24 PM
LudeSi-93
Jun 25, 2001 04:19 PM
