JE Pistons...
Old Oct 21, 2001 | 09:16 PM
B18CHatch's Avatar
Default JE Pistons...
Hey guys, I was searching the internet and I came across a site that seems to have pretty good prices on JE pistons. Here's the link: http://www.flatlanderracing.com/jepistoncompacts.html
They're selling them for $379/set, is this a pretty good price?
Old Oct 21, 2001 | 09:31 PM
TurboInteg95's Avatar
Default Re: JE Pistons... (B18CHatch)
watchout, pins NOT included.
Old Oct 21, 2001 | 09:46 PM
B18CHatch's Avatar
Default Re: JE Pistons... (TurboInteg95)
I see...does Race Engineering include the pins with the JE Pistons? Do I need to use JE pins or could I use Honda pins? Thanks.
Old Oct 21, 2001 | 09:53 PM
I think you need to use JE pins and keepers as well. stock pistons are pressed onto the pins, JE's are free-floating.
Old Oct 22, 2001 | 12:02 AM
Trajic's Avatar
New User
Get them at Race Engineering engenerring they are very cool. Resently got my je pistons and eagle rods from them. They came with everything rings pins
Old Oct 22, 2001 | 05:39 AM
Davep's Avatar
Default Re: JE Pistons... (Trajic)
How much did the rods and pistons cost total from Race?
Old Oct 23, 2001 | 03:36 PM
ArizonaTurbo's Avatar
Default Re: JE Pistons... (Davep)
JE Pistons - $369.00 (Includes Pins & Clips)
JE/SRP Rings - $90.00
Eagle Rods - $369.00
http://www.raceeng.com
Old Oct 23, 2001 | 04:41 PM
shingles's Avatar
Default Re: JE Pistons... (APEXSER)
are those actual JE or SRP?
-S
Old Oct 23, 2001 | 04:44 PM
dustin's Avatar
Default Re: JE Pistons... (shingles)
JE for $369? I do not think so.
Old Oct 23, 2001 | 04:49 PM
Default Re: JE Pistons... (dustin)
I do stand corrected! I was thinking SRP's! JE's are ~$400.00.
Old Oct 23, 2001 | 06:05 PM
shingles's Avatar
even $400 is still a lot cheaper than I've seen anywhere else....
-s
Old Oct 23, 2001 | 06:18 PM
sgT's Avatar
sgT
All pistons are full floating. The pins are pressed onto the RODS.
Most aftermarket rods are full floating. stock rods are not.
Old Oct 23, 2001 | 06:23 PM
DirtyLude's Avatar
Default Re: JE Pistons... (sgT)
That depends on what model/year engine you have.
Old Oct 23, 2001 | 06:32 PM
sgT's Avatar
sgT
Default Re: JE Pistons... (DirtyLude)
That is true. I forgot about f and h motors.
Old Oct 23, 2001 | 09:56 PM
trans4mer's Avatar
dont forget srp are made from je they are pretty much the same thing just different name so they can be sold cheaper
Old Oct 24, 2001 | 08:05 AM
dustin's Avatar
Default Re: JE Pistons... (trans4mer)
They are much weaker, high silicon content pistons.
Old Oct 24, 2001 | 08:35 AM
LEON's Avatar
Much weaker to what extent? Does anyone have composition break down and tolerence figures for both? I'm curious to know how different or similar they really are.
Old Oct 24, 2001 | 11:48 AM
I was under the impression that:
Low Silicon Pistons
JE
SRP
Ross
NON Silicon Pistons
Wiseco
High Silicon Pistons
Arias
What does this mean?
High Silicon Content - Very Little Expansion
Low Silicon Content - Expansion with heat
NON Silicon Content - A lot of Expansion
The Arias pistons run very tight piston-wall clearances (ie: .001"-.003")
The JE/SRP & Ross Pistons run tight clearances (ie: .003"-.0035")
The Wiseco Pistons run loose tolerances, but still well within factory specs (ie: .004"-.005")
Most forced induction cars should run .003"-.0035" piston-wall clearances!
Old Oct 24, 2001 | 12:05 PM
turbopanda's Avatar
Yeah that's strange.. my friend was running crower rods and JE pistons originally in his 1.8bar D16Y8 turbo setup, and that lasted him about 2 weeks. After that, he changed over to arias pistons, and he's was running fine.. he told me to stick with arias.. more reliable, stronger, and cheaper.. whether its true or not I dont know..
Old Oct 24, 2001 | 12:14 PM
sgT's Avatar
sgT
Default Re: JE Pistons... (LEON)
every SRP pistons I have seen used under boost has failed.
Old Oct 24, 2001 | 12:47 PM
Rob03Pro5's Avatar
Default Re: JE Pistons... (nathan's boosted civic)
Nathan, It could be that he didn't let the car warm up to run.. Those low silicon content pistsons (JE's) need to be warmed up before abusing them. I know tons of cases where JE pistons hold more than 20 psi.
Old Oct 24, 2001 | 03:12 PM
dustin's Avatar
Low Silicon Pistons
JE
SRP
Ross
NON Silicon Pistons
Wiseco
Arias
I think you have some of it backwards.
From an SRP advertisement "SRP: High silicon alloy for tighter piston to wall clearance"
Arias pistons have very low silicon content. JEs are low silicon content. Both should be FULLY warmed up before driving on them. Arias pistons slap pretty bad until they are warmed up.
The SRP pistons are high silicon content and do not require as much attention to warming up as the others. They are also much weaker, and melt at lower temperatures.
Dustin
Old Oct 24, 2001 | 03:18 PM
DirtyLude's Avatar
Like Dustin said.
In the catalog they advertise the pistons for mild turbo and nitrous use. They shouldn't be used for anything more.
Bonestock98GS
Oct 1, 2009 05:10 PM
VTiVTo8000rpm
Jan 19, 2005 05:48 AM
Nextelbuddy
Dec 31, 2003 11:44 AM
BlueSi2k
Mar 7, 2003 07:50 PM
93B17A
Jan 26, 2002 06:47 PM
