Using Prelude Injectors
Old Oct 17, 2001 | 10:55 AM
Dravis's Avatar
New User
Default Using Prelude Injectors
Hey guys,
To anyone who has directly done this swap, or knows 100% for sure:
I have a B17a1 OBD1 VTEC motor, running 10 PSI. I need larger injectors. We want to do the preludes, just because I can get them for dirt. I know the 93-95 have OBD1 330ish cc injectors...do they bolt right into my AEM fuel rail? I know they will supply enough fuel with my regulator.
Anyone who has done this and can give me any pointers, I appreciate it!
Alex
Old Oct 17, 2001 | 11:23 AM
VTC_CiViC's Avatar
Default Re: Using Prelude Injectors (Dravis)
The OBD-I Lude injectors were P&H, and if i'm not mistaken so were the 2G Integra's, so yea they should be no problem. I have a set of injectors from a 94 VTEC Lude if you need em'.
Old Oct 17, 2001 | 12:38 PM
sgT's Avatar
sgT
Default Re: Using Prelude Injectors (VTC_CiViC)
90-91 integras used peak hold. 92+ used saturated. So he will need to get
a resistor box
Old Oct 17, 2001 | 06:18 PM
The Punisher's Avatar
Default Re: Using Prelude Injectors (sgT)
sgT is right, and yes they will fit into an AEM fuel rail. I got my Fuel rail yesterday and fit my injectors in just to make sure. By the DSM injectors work too, thanks sgT!
Old Oct 17, 2001 | 06:23 PM
dustin's Avatar
You will need some sort of fuel computer to control them, like a V-AFC. Tell me you are not still using just the paxton regulator? You need something boost dependent!
Dustin
Old Oct 18, 2001 | 05:46 AM
Dravis's Avatar
New User
Default Re: Using Prelude Injectors (dustin)
Ok...so all we could source was 450cc DSM injectors...but I dont think I want to run these without some kind of fuel control. We can always turn the base pressure down to 35 and see what we can tune out of it...
Im positive the paxton is going to work just fine, I just need injectors to get the right amount of fuel from the rail.
Old Oct 18, 2001 | 08:05 AM
dustin's Avatar
Heh, Dravis. Listen to me.
The Paxton is a 1:1 regulator. The entire point of having a 1:1 regulator is because the manifold is pressurized under boost. When you are under 15psi of boost, it takes 15psi MORE fuel pressure to get the exact same fuel delivery! 1:1 Regulators do not enrich fuel with boost!
Your "tuner" is smoking crack. I would not let anyone this uninformed "tune" my car.
Either get big injectors and a standalone, big injectors and a V-AFC, stock injectors and FMU and fuel pump. Just using a 1:1 FPR is not going to compensate for fuel under boost.
Listen to me before you have to shell out extra $$ just to get it working right.
Dustin
Old Oct 18, 2001 | 12:03 PM
SiRkid's Avatar
will i be able to run 310's with the vortech fmu at 8:1(for 10 psi of boost) with a t3/to4e and be fine without a vafc????
thanks
Old Oct 18, 2001 | 10:50 PM
Giuseppe's Avatar
Default Re: Using Prelude Injectors (SiRkid)
Wohoooo..
another nonOBD guy using the OBD1 prelude 310's..!!!!
all u RC guys are just followers!!!!
haha, jfwy
Old Oct 29, 2001 | 03:37 PM
KJEG94's Avatar
New User
Default Re: Using Prelude Injectors (Giuseppe)
DUSTIN knows his ****.. but hey. dravis said he will hook anyone up with his good mechanic if your in washington. i say we all go have him install turbo setups on our rides. hes the best!!!!
Old Oct 29, 2001 | 05:44 PM
TurboInteg95's Avatar
SIRKid, 310's with an 8:1 regulator work fine without an AFC, thats' what I'm running. As for this whole 1:1 regulator thing, HAHAHAHA.
Matthew98DX
Oct 31, 2016 06:28 AM
airwalk07143
Dec 30, 2008 05:56 AM
Propulsion
Dec 17, 2003 08:39 AM
true
Oct 1, 2003 10:18 PM
MartGSR
Jul 21, 2002 04:50 PM
