Fmax--Need to cut the radiator fan shroud
New User
yet another problem...not a bad one though.
You will have to cut the fan shroud in order for the fan to go back in and fit around the compressor. It is essential to remove the fan (if not the whole radiator to eliminate other headaches--i left mine in) in order to get the manifold/turbo/compressor combination onto the engine block. then to get the fan back in just cut some of teh plastic off the shroud to get it to fit.
I was hoping not to have to do that but it had to be done. Another thing to let Fmax know about.
tf
tf
New User
Re: Fmax--Need to cut the radiator fan shroud (immortal)
thanks for letting me know. I feel better knowing I'm not the only one chopping up my car for a "direct bolt on"!
Re: Fmax--Need to cut the radiator fan shroud (GruvyTune)
How much of the shroud did you cut!? Any blade cutting.....? F-max is not keeping their word here!!
[Modified by MiraiZ, 10:22 PM 10/21/2001]
Re: Fmax--Need to cut the radiator fan shroud (TurboR616)
either cut out the piece that u need or i would suggest to just get a slimmer fan from almost any parts store and just use that
New User
Damn.
Look at that thick *** piping. Ours isn't nearly that thick.
I only had to cut a little bit. Perhaps 6x4 in.
I'll post pics later tonight.
or you can do what alot of us do and get a slim fan.
Re: Fmax--Need to cut the radiator fan shroud (LsTurbo91)
They have to be 'pull' fans. You want to pull ambient outside air through the radiator
Dustin
Dustin
reverend....did you have to cut your shroud too??
[Modified by MiraiZ, 12:14 PM 10/22/2001]
