I BOOSTED!.....for a second anyhow
Old Oct 23, 2001 | 06:58 PM
Mr. Vapor's Avatar
Default I BOOSTED!.....for a second anyhow
Well i boosted today guys! HOLY **** THE THING PULLED LIKE A ******* MACHINE! i was in awe......then it happened.....i blew a ******* intercooler pipe off, the clamps didnt hold. so i was like ok, limp it home, tighten it back on.......then back out i go! only to have the same thing happen in a different spot.....
what the hell do i do? how can i get my clamps to hold, am i boosting THAT much, i didnt get a chance to look at my guage since it happened so fast.
also a concern i have, whats the max boost i can get at this set up, cause i dont want to hit it. I run Drag with RC 340s, Tial 35mm (.3 bar spring) and Turbo XS MBC. i dont want to run more then 6 psi at this time, how can i make sure i dont go anymore then that, and what is the max the car could hit with out me knowing?
what do i do about my I/C pipes? does anyone have this problem
Old Oct 23, 2001 | 07:07 PM
maxim's Avatar
Default Re: I BOOSTED!.....for a second anyhow (NYb16)
congratulations!!!!....well, almost. Sorry about your clamps.
Old Oct 23, 2001 | 07:11 PM
TurboIntegra's Avatar
Default Re: I BOOSTED!.....for a second anyhow (maxim_force)
I hope you aren't using a screwdriver to try and tighten them. You will never be able to get them tight enough.
When I use a socket or wrench I can torque them down extra tight.
Or you can get much stronger clamps. I forgot where I got mine.
Old Oct 23, 2001 | 07:16 PM
Mr. Vapor's Avatar
Default Re: I BOOSTED!.....for a second anyhow (TurboIntegra)
tommrow AM i plan on going to loook for stronger hose clamps, and i used a screwdriver handle with a socket drive.....tommorow i will cut the bullshit, and go right for the ratchet.....any suggestions though?
Old Oct 23, 2001 | 07:21 PM
maxim's Avatar
I think he was referring to a regular socket wrench to get some good leverage you probably won't get a good grip on the screwdiver handle when tightening.
Old Oct 23, 2001 | 07:22 PM
dustin's Avatar
I use a 1/4" drive ratchet to tighten IC clamps. Nothing else works.
Dustin
Old Oct 23, 2001 | 07:24 PM
Anthony K's Avatar
New User
Default Re: I BOOSTED!.....for a second anyhow (dustin)
Use coarse sandpaper to scuff the last 3/4inch of each pipe end. Should help with gripping. That's what I was told to do to mine...works fine.
Old Oct 23, 2001 | 07:31 PM
SEFIxCivic's Avatar
Default Re: I BOOSTED!.....for a second anyhow (Anthony K)
what always worked for me was bending a lip on the end of each pipe with vicegrips. it doesn't look pretty but its covered by the coupler and never gave me problems even @ 24 psi
Old Oct 23, 2001 | 07:34 PM
TurboTegB18c's Avatar
Yeh, that's the way to do it!
Old Oct 23, 2001 | 07:38 PM
DirtyLude's Avatar
Default Re: I BOOSTED!.....for a second anyhow (SEFI8LOxCivic)
If you find a shop that has one you can use a beading machine to create a bead on the ends of the pipes. It's just a tool that presses out a bead in the pipe. Otherwise just use that vicegrip idea, I like that one.
You can also get T-Bolt clamps which are a heavy duty clamp that you can only use a ratchet on. You can tighten them up like a mother... Well, anyway, is it blowing before the intercooler only?
cokex's Avatar
Default Re: I BOOSTED!.....for a second anyhow (TurboD16Z6)
you can tiighten the crap out of the clamps .. or u can do it this way ..
beeding the ends of the ic pipes ..
check it out here ..
http://www.roadraceengineering.com/e...icpipebead.htm
Old Oct 23, 2001 | 08:11 PM
Mr. Vapor's Avatar
Default Re: I BOOSTED!.....for a second anyhow (cokex)
awesome! great ideas everyone! i'll let you know how it turns out tommrow
Old Oct 23, 2001 | 08:28 PM
VTC_CiViC's Avatar
I used to have a problem with my IC pipe directly connected to the turbo housing, used to either pop off or the coupler would explode altogether. I switched to a thick radiator hose and haven't had a problem since. Got those clamps tied down hard thanks to a racthet set too, definatley gonna wanna use one of those.
Old Oct 23, 2001 | 09:58 PM
VaporTrail's Avatar
New User
I like my three step method for the DRAG piping
1. course sandpaper to provide friction
2. T bolt's - available at NAPA for 1.25 (or from Turbonetics for 7.00!)
3. Bead welding. Just have some dots of weld put around each end of each pipe, one each at 12, 3, 6, and 9 o'clock positions
Never had a problem
Old Oct 23, 2001 | 11:36 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: I BOOSTED!.....for a second anyhow (VaporTrail)
Never had a problem
Exactly what I did and has worked wonders. Vapor has it down...
Old Oct 24, 2001 | 06:43 AM
Rival's Avatar
New User
oh yeah it was definitly fun!!! for all who don't know me, i am NYb16's little brother and when the boost kicked in...no words could explain except "my neck hurts"!!!
Old Oct 24, 2001 | 08:02 AM
dustin's Avatar
NAPA carries those T bolt clamps? Hmm I need some of those.
Old Oct 24, 2001 | 08:18 AM
Evil DOHC's Avatar
Double clamp and use a rachet.
Works for 15 psi of boost.
EVIL
Old Oct 24, 2001 | 11:27 AM
paulzy's Avatar
Default Re: I BOOSTED!.....for a second anyhow (Evil GS-R)
weld beads on the end of the pipes
Old Oct 24, 2001 | 11:58 AM
Jared's Avatar
Never had a problem
Tbolt clamps are available at napa? Where? never seen them.
Old Oct 24, 2001 | 12:17 PM
VaporTrail's Avatar
New User
Default Re: I BOOSTED!.....for a second anyhow (Jared)
yeap, at least in Tampa they do. Also, Ford and Dodge turbo diesals use them from the factory
turboH22Aakkord
Aug 26, 2005 06:36 AM
RotiEatter
Jun 5, 2004 10:00 AM
homesauce
Mar 12, 2004 01:56 PM
GraphiteAccord
Jun 28, 2003 02:02 PM
revhrdls
Nov 8, 2001 11:36 AM
