problems problems problems....
Old Oct 22, 2001 | 09:18 AM
TurboT's Avatar
Default problems problems problems....
after finally getting a hondata stage 4b in...
finding out that the 720cc Greddy injectors don't fit... and going with some 440cc injectors at high fuel pressure
i took to the track sunday morning with 1.5 hours of sleep.... by the way, THANKS STEVE AND VICTOR.... thanks a million for your help... i'll call you in a bit steve to give you the low down....
but anyways, here's the senario...
1st run... bouncy launch on drag radials... grip then..... BAAAAAA.... bog bog bog.... and then the car picks up like it's on nitrous.... come back to the pits and regap my plugs...
2nd run.... smaller gap, but still bogs like crazy at vtec.... misshifted into 4th gear and bounced off the rev limiter.... remind you, my motor was built to take 10k rpms.... engine still idling fine afterwards...
3rd run... before the run- i checked the oil level and the oil was low.... prior to racing my oil level was checked out and at normal levels.... filled it back up to between the two holes of the dip stick... proceeded to the burn out box... good launch.... then all of a sudden.... no power... revs are just bouncing around the vtec point like i have a 2 stage rev limiter on or something.... then the car picks up like crazy again... i shut it down way before the finish...
i stop in the return lane to help out a friend that blew his head gasket.... the car is in idle... i'm there for about 10 minutes...
come back to the pits... give up for the day... but what's this? my car is smoking a bit... white smoke coming out the rear.... not thick and not thin... but medium density.... i leave the car on idle for 10 minutes... and then it stops smoking....
after that, we decided to leave for teh day... on the way home though, well actually leaving the pit area... i noticed that my oil pressure would not go past 50 psi of pressure.... my oil pressure sender is tapped right where the stock oil pressure switch is... i tried revving up and seeing if it was the gauge.... but the car wouldn't even go into vtec anymore.... the car is like it has a rev limiter setup right at the vtec engagement point... sputter sputter sputter....
while revving up, i also noticed that the same smoke was back again.... same color and density...
oh well, i ease it back home...
this morning, i start up the car.... the smoke was back.... and still the oil pressure won't go past 50 psi...
once the car warmed up though, the smoke thined out greatly.... at work, there was no smoke at all....
anyone have any ideas?
b18bturbo thinks it's the oil pump.... but my friends think that if it was the oil pump, the car would have no oil pressure at all....
also, as for the smoke.... they all think my head gasket is toasted.... agree? disagree?
man, bad weekend.... no sleep, car running like crap, car dying... sheesh...
although, it was a pleasure to finally meet you steve....
thanks all
well
[Modified by TurboT, 10:18 AM 10/22/2001]
Old Oct 22, 2001 | 09:28 AM
rtype11's Avatar
Default Re: problems problems problems.... (TurboT)
could be a million things with your car, I will tll you one thing I know for sure, the oil pump gear will shatter when you hit higher revs like you said you motor is good to 10K. buy the aftermarket oil pump gear. Even the R type gear will break.
Hope you do not have any chocolate milkshake in your coolant????
Old Oct 22, 2001 | 09:30 AM
TurboT's Avatar
Default Re: problems problems problems.... (rtype11)
well, if anything.... i think somethine was going funcky with my oil pressure all day... i believe that's why the car couldn't go into vtec smoothly...
i test drove the car the night before the race, and it was freakin fast...
but of course, all the problems came on race day...
i'm thinking of going with a GSR oil pump with the pro drive oil pump gear as B18Bturbo recommended to me... right viren?
Old Oct 22, 2001 | 09:46 AM
rtype11's Avatar
Do you have an LS motor? if so get the 94 GSR oil pump and '98 Type R water pump and 94 GSR timing belt + the prodrive gear.
[Modified by rtype11, 10:47 AM 10/22/2001]
Old Oct 22, 2001 | 09:50 AM
TurboT's Avatar
nope, GSR motor.. with ITR head
Old Oct 22, 2001 | 10:05 AM
G_Man604's Avatar
i already busted 2 oil pumps (type r) dyyyyaaammm! so like turbot said, get an aftermarket oil pump/gear. i'm getting a toda one
Adi Radoncic's Avatar
On Fire!
Dang Terry,
sorry to hear that about your car I hope you get it back up and running good!!
Adi
Old Oct 22, 2001 | 12:01 PM
TurboT's Avatar
Default Re: problems problems problems.... (newgsr)
g_man.... so is what i'm seeing an oil pump gone bad?
adi,
no kiddin.... damn, my car was feeling so good when we went for a test drive...
and then mechanical problems.... of course it has to happen... f'd up murphy's law...!
Old Oct 22, 2001 | 12:56 PM
markaria's Avatar
how much are the aftermarket oil pumps/gears? who all makes them?
Old Oct 22, 2001 | 02:59 PM
quikrpm'z's Avatar
Turbo T, i have the same problem. I smoke when the car is cold(during start up) then it stops. My oil gauge wont go past 50psi either. do u have an autometer gauge.
Old Oct 23, 2001 | 07:59 AM
SlowTeg's Avatar
Sorry to hear about all the problems you had.. Just gotta question for you though.. What didn't fit with the greddy injectors.. Did it not fit into the rail? Was it too big or too small? Just curious, because I was looking into getting a set myself. Thanks.
-Mike
Old Oct 23, 2001 | 08:22 AM
pornstarSR's Avatar
just a quick question, what oil are you running. cause if the oil is to thin it wont engadge the vtec solinoid......but that wont explain your run running, other than if your using a bigger map senser but havent told the hondata to use the gm version.
Old Oct 23, 2001 | 08:55 AM
TurboITR's Avatar
Default Re: problems problems problems.... (pornstarSR)
engadge
Old Oct 23, 2001 | 11:23 AM
TurboT's Avatar
Default Re: problems problems problems.... (quikrpm1)
quikrpm1, any solutions?
sounds exaclty the same... i have an autometer electronic oil pressure gauge....
oh yeah, did a compression check... 165 across the board....
no oil in the coolant...
doesn't sound like a headgasket
Old Oct 23, 2001 | 11:31 AM
HX_Guy's Avatar
165? Isnt that WAY low?
Old Oct 23, 2001 | 11:37 AM
TurboT's Avatar
Default Re: problems problems problems.... (HX_Guy)
i'm running on JE 9:1 compression pistons....
mated to a ITR head that had combustion chamber rework....
my compression is approx 8.5:1
Old Oct 23, 2001 | 11:39 AM
HX_Guy's Avatar
Oh...nevermind
Old Oct 23, 2001 | 03:21 PM
quikrpm'z's Avatar
TurboT,
unfortuneatly I dont. I checked with a good acura mechanic about the oil gauge. He claimed that the oil pump has a spring that regulate pressure, and that if it goes beyond a certain psi, it would only allow a max of 50psi. Has anyone else ever heard of this?
Old Oct 23, 2001 | 03:28 PM
TurboT's Avatar
yeah, i was checking out my helms manual...
and there is a bypass valve in the oil pump... basically if the spring isn't strong enough, it will just bypass the oil into the pan....
i guess time for a new oil pump!
Old Oct 23, 2001 | 03:32 PM
Jared's Avatar
the spring is behind the allen plug on the back of the pump.
joel n
Sep 27, 2012 04:37 PM
k20powered
Honda Civic (2006 - 2015)
12
Aug 19, 2008 07:46 PM
em1gangsta
18
Jun 10, 2008 09:37 AM
gosu08
Sep 9, 2007 12:23 PM
Mark's Mechanic
Nov 4, 2001 02:39 PM
