how to read compressor maps?
Old Oct 23, 2001 | 08:27 AM
TypeC's Avatar
Default how to read compressor maps?
So, how do you interpret these graphs? I know cfm matters, as well as spool time, but how can you figure any of this out from the graph?
tia,
-C
Old Oct 23, 2001 | 10:35 AM
Turbolude's Avatar
Default Re: how to read compressor maps? (TypeC)
ttt
Old Oct 23, 2001 | 10:43 AM
Giuseppe's Avatar
try this website...
it'll give u what u need...
HTH
http://www.badbricks.com/main_files/faqs/turbo_size.htm
Old Oct 24, 2001 | 12:41 PM
TypeC's Avatar
Default Re: how to read compressor maps? (Giuseppe)
sweet, I understand now.
so much so, i made an internet program to calculate CFM and PR for you:
http://velocity.websitegalaxy.com/cfm.html
Old Oct 24, 2001 | 12:50 PM
Rob03Pro5's Avatar
Uhm.. according to your calculations, my car will be boosting 10psi by 2000rpm. LOL! I wish.. Also, you have 10psi as 1.78 for PR.. that is wrong. It should be 1.68 whether you use 14.5 or 14.7 as atm pressure.
Old Oct 24, 2001 | 03:59 PM
Ricehornet's Avatar
https://honda-tech.com/zerothread?id...=426217#426217
Old Oct 24, 2001 | 04:11 PM
G's Avatar
G
Input your info and it will plot it automatically. You can compare between maps.....
http://www.turbofast.com.au/turbomap.html
Old Oct 25, 2001 | 08:15 AM
TypeC's Avatar
Default Re: how to read compressor maps? (Rob92SC)
you have to enter the rpm that you reach full boost at, Otherwise it assumes you always have full boost. The little check bock will add 1.5 psi to the numerator for the PR calculation. Don't go off now, I just barely made the thing in a couple hours! I'm not trying to sell it.
I can't use the other one because my work computer doesn't use the JAVA.
-C
[Modified by TypeC, 11:34 AM 10/25/2001]
Old Oct 25, 2001 | 08:26 AM
TypeC's Avatar
what I meant about intercooler loss is:
PR= (boost+ATM)/ATM
I was told the intercooler loses ~1.5 psi so I did
PR= (boost+ATM+1.5)/ATM
where ATM=14.7 psi. If that 1.5psi addition is wrong, just DON'T check the box.
-C
Old Oct 25, 2001 | 08:48 AM
VTC_CiViC's Avatar
Usung Turbofast's calculations, I was reccomended to go with a Garett T-25 for my D16 for 12psi, anybody know where these T-25's are found?
Old Oct 25, 2001 | 10:34 AM
Rob03Pro5's Avatar
Default Re: how to read compressor maps? (VTC_CiViC)
I wouldn't go with those turbo calculations.. they have good programs for getting hp and flow maps.. but their "recommended turbo" program sucks. For your D16, get like a T04b/T3 S3 trim (big), T3 Super 60 (medium), T3 60 (medium), or a 16g.
Old Oct 25, 2001 | 12:54 PM
VTC_CiViC's Avatar
Hmm I dunno, you don't find a T04 to be just a touch LARGE for a D16? Thanks for the 411 on turbofast's page though. I used their "Drag Racing" calculator and it was actually remarkably acurate with my last trip to the track, but I guess I'll take their reccomendations with a grain of salt heh
Old Oct 25, 2001 | 01:33 PM
Rob03Pro5's Avatar
Just assuming that a T04 is large is not right. There are many different trim levels. The T04b/T3 S3 I mentioned is just a little larger than a T3-super 60. The same turbo is smaller than all the turbo's that DRAG and RevHard offer in their kits.. so yes it is small enough for the D16. Just make sure you get a .48 ehaust housing.
Old Oct 26, 2001 | 10:39 AM
VTC_CiViC's Avatar
Ok, now this is gonna be the basic of basics.. I'm pretty familiar withthe Mitsu system of turbo's (TD's and their corresponding wheels sizes like m 15G), but I'm dead ignorant with Garett's/Turbonetics "T" turbo's. I mean I "kinda" understand a little, T25 is pretty small, T3 is a little larger, T4 etc.. but is there a good internet resource where I can kinda compare turbo sizes by their label? Oh and thanks for the info Rob
$MIKE$
Jun 23, 2014 11:13 AM
Dialectic
Jun 4, 2006 04:54 PM
Boostless97Lude
Mar 30, 2003 07:21 AM
HXMan
Dec 17, 2001 03:54 PM
