Max boost on non-sleeved block?
Old Oct 18, 2001 | 12:28 PM
B18CHatch's Avatar
Default Max boost on non-sleeved block?
Hey, I was wondering what is the maximum boost I could run on a B18C1 block without re-sleeving it? I would put lower compression pistons and stronger rods in the block. Is 350 whp achievable without resleeving? Thanks!
Old Oct 18, 2001 | 01:35 PM
FAST94GSR's Avatar
New User
Default Re: Max boost on non-sleeved block? (B18CHatch)
14-15lbs. that should do 350 with proper tuning. I've seen others push more but I would play it safe.
Old Oct 18, 2001 | 01:43 PM
Kamin's Avatar
Default Re: Max boost on non-sleeved block? (FAST94GSR)
what about a block guard instead of resleeving?
whats max then?
Old Oct 18, 2001 | 01:44 PM
dustin's Avatar
Default Re: Max boost on non-sleeved block? (KAMiN)
A block guard does not strengthen the sleeves, it just keeps them from floating around. They could still expand under boost.
Dustin
Old Oct 18, 2001 | 02:16 PM
Kamin's Avatar
Default Re: Max boost on non-sleeved block? (dustin)
doh
thats what happens when you dont think.
stupid lack of sleep.
if you can tell me, hhow much does a resleeve cost and where can it be done if its not a do t yorself project (i dont think it is)
Old Oct 18, 2001 | 02:53 PM
redline's Avatar
depands but about 700-1000 depanding on what you get done.
http://www.goldeneaglemfg.com
Old Oct 18, 2001 | 03:06 PM
jinxproof99's Avatar
New User
450 to the wheels should be no problem if your tuned properly (dfi, haltech, speed pro, motec) and the rest of the block is done right. more than that is possible, but you might have some problems down the road. i'll be running 450+ to the wheel in the spring on a built block(not-sleeved). we'll see what happens. other people have done it before.
tobe1424
Aug 16, 2005 10:11 AM
PIFFSTAR
Feb 15, 2005 06:49 AM
CANTFAZZDISCHIT
Jul 9, 2004 07:18 PM
bluedelsol
Jul 10, 2003 02:56 PM
aut0tek
Apr 2, 2003 02:50 AM
