Block Sleeving?
Old Oct 24, 2001 | 08:55 AM
DeL B18C SoL's Avatar
Default Block Sleeving?
I did a searce, but really could not find an answer to my question. Anyways I have a B18C1 in my Del Sol w/ Drag Gen III and I just blew the motor. I'm going to build the bottom end now, and was wondering if there would be any negative effects on the motor if I sleeve it w/ a 84.5mm bore to increase displacement?
Old Oct 24, 2001 | 09:07 AM
bigTom's Avatar
Default Re: Block Sleeving? (DeL B18C SoL)
just make sure the sleeves can handle that bore so as it does not thin them out too much and also just make sure u have someone who knows what they are doing put it together... to my knowledge... u also have to modify the combustion chamber a little bit
Old Oct 24, 2001 | 10:36 AM
D-SPEED's Avatar
Default Re: Block Sleeving? (ek9t)
check out my thread in engine tech....
ek9t- why would you need to change the combustion chamber ?
boostedb20ek
Sep 9, 2010 03:39 AM
idriveadelsol7
Apr 19, 2005 08:52 AM
underpressure02
Feb 19, 2003 05:18 AM
Quik Chris
Dec 21, 2002 10:11 AM
Outkast_CL9
Sep 1, 2002 02:25 PM
