Anyone need?
Vortech Super FMU with 4 different calibration disks, static fuel pressure adjustment, -6AN inlet and outlet fittings, max pressure limit adjustment, vacuum to pressure adjustment, used for a month - $230 shipped
-Allows complete tuning of fuel pressure curve relative to manifold pressure, including upper and lower limits.
-Can be used in series or stand alone and can be used to adjust static pressure.
-Recommended for high horsepower applications which require finite fuel curve tuning.
-Replaces non-adjustable FMU included in Vortech supercharging systems.
-Includes Super FMU, mounting bracket, mounting screws and addtional components for recalibration.
J&S ultra safeguard version 2, knock sense retard, map sensor electronic limiter, boost / timing control, a/f gauge with normal and performance selection, a/f gauge and knock monitor, used for a month - $600 shipped
i'll include some -6 an lines and fittings for the FMU so that you can hook that bad boy up to either an aftermarket FPR or stock FPR... or if you want to run it by itself, i can send you some adapter fittings to aftermarket and stock fuel rails...
thanks!
thanks!
poo....
$200 shipped for the FMU...
oh yeah...
if anyone needs say like, a oil drain braided line kit, stock fuel filter or aftermarket fuel filter to aftermarket fuel rail fuel line kit, or anyother AN line related items... lemme know... i have about $1000 worth of AN stuff laying around and can build you kits or sell you adapter fittings...
terry
oh yeah...
terry
I need the fittings for my -4AN SS oil inlet line. I need the fitting that links the SS line to the T in the back of the block, as well as the fitting that links the SS line to the turbo. If you have these I will buy. Let me know at Evansjs@lafayette.edu.
Thanks, Jeff
Thanks, Jeff
turbogsr13z
Apr 17, 2002 09:39 PM
