K24a2: AFI Turbo Kit - Pump Gas Dyno Tune
Old 02-28-2011, 03:50 AM
Spent's Avatar
Default K24a2: AFI Turbo Kit - Pump Gas Dyno Tune
Nhia has been a TDC customer for a while now. We've had his RSX-S in the shop on several occasions for upgrades and tune. He recently decided to get a turbo car, and bought this Midori Green EK hatch. We had the hatch in today for several repairs, and a tune on Hondata.
Here is the setup:
Bone Stock K24a2
AFI GT35R Turbo Kit
Walbro 255LPH Fuel Pump
Precision 1000cc Injectors
AEM Injector Driver
Hondata K Pro
Hondata 4 Bar MAP Sensor
Here are the results:
This chart is at 14 PSI. Nhia plans to come back soon to have us install ARP head studs, a new Head Gasket, and IPS cams.
Click for vid: http://www.youtube.com/watch?v=9YFFjaavuHs
The following chart was the last run. All we did was lower vtec point and adjust down low to increase power and spool up. There was no sense in doing another full rpm run on a heat soaked setup when the top end was already tuned, hence the short run.
Old 02-28-2011, 04:52 AM
D-Rob's Avatar
Default Re: K24a2: AFI Turbo Kit - Pump Gas Dyno Tune
25deg VTC, or swapped out for 50?
Old 02-28-2011, 05:44 AM
Spent's Avatar
25.
For comparison purposes in regards to how our dyno reads, a k20 with your average bolt on's (tuned) will net between 181-193 whp pretty consistently.
Old 03-05-2011, 12:32 PM
Spent's Avatar
We tuned this one last night.
https://honda-tech.com/forums/forced-induction-16/gsr-block-type-r-head-60-1-turbo-e85-dyno-tune-2906144/
Old 03-05-2011, 03:03 PM
Vtec-G2teg's Avatar
Nice kit nice numbers!
Old 03-06-2011, 09:37 AM
mar778c's Avatar
Nasty piece of work. Traction will be an issue.
Old 03-07-2011, 04:35 AM
Spent's Avatar
^ Yes. Slightest throttle input and it's roasting time.
Old 03-07-2011, 02:03 PM
turbohatch96y7's Avatar
Nice very nice
Old 02-06-2015, 11:39 AM
KidRuthless's Avatar
How long did this set up last
Old 02-06-2015, 11:55 AM
Who is Mr Robot?
wantboost's Avatar
A 4 year old thread where the OP hasn't been active for a year... Doubt you're getting a response. Since AFI has been out of business for a while I doubt the kit reliability had any relevance since you can no longer get the kit
Spent
06-25-2010 06:43 PM
mnlude
01-27-2006 10:58 AM
redboost10
12-03-2003 06:17 PM
boosted hybrid
08-18-2003 08:45 PM
crx1856
05-17-2003 02:48 PM
Quick Reply: K24a2: AFI Turbo Kit - Pump Gas Dyno Tune
