skunk2 or bc
Old Mar 1, 2011 | 04:24 AM
1fastlude1's Avatar
Default skunk2 or bc
im looking to get cams finally for my h22 which cams have yall had better numbers with skunk2 or brian crower, and also which cam the bc turbo or the stage 3, im runnin hondata 9.1 mahles, 16 psi, 880cc inj, thanks
Old Mar 1, 2011 | 04:36 AM
MR.johnson's Avatar
Default Re: skunk2 or bc
every one seems to run pro1's. im getting a set soon.
Old Mar 1, 2011 | 07:44 AM
ryguy2588's Avatar
I would go Skunk2 all the way. My friend took his engine to be assembled at a machine shop and as they slipped the timing belt over the cam gears, one of the BC cams just snapped off at the end of the head. He sent them back and after a lot of talking they sent him a new set, but after seeing that, I don't think I could ever trust BC cams.
Old Mar 1, 2011 | 08:11 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I'd go skunk :-)
Old Mar 1, 2011 | 09:32 AM
1fastlude1's Avatar
Originally Posted by ahobbs
I'd go skunk :-)
which skunk 2's tuner or pro's and which cam? idk which one would be better for boost
Old Mar 1, 2011 | 10:35 AM
Mr. EG's Avatar
Call Skunk and ask them what they reccomend for your setup.
Old Mar 1, 2011 | 11:26 AM
ryguy2588's Avatar
I'd go skunk :-)
Hey Hobbs,
Are you the fireman in Texas with the red eg? I saw ur name and I read an article about ur car in Honda Tuning if thats you.
Old Mar 4, 2011 | 07:27 PM
1fastlude1's Avatar
does anyone have dyno charts comparing s2 pro1's and bc turbo cams and stock and jdm cams im reading all kinds of different info sayn stock or jdm cams are best and skunk 2 are best i cant find any good info for h22 cams for boost, i have stock h22a jdm cams now, they work great but im wanting more power especially mid range someone please help with good info
Old Mar 4, 2011 | 08:04 PM
B20luda's Avatar
whats your setup...
people are making well over 700whp on oem cams
Old Mar 4, 2011 | 08:14 PM
TheShodan's Avatar
Moderator
Exactamondo.
Old Mar 4, 2011 | 08:15 PM
TheShodan's Avatar
Moderator
That depends upon what turbocharger your friend is using. Anything under 65lbs/min, and he might as well keep what he has. There's no point in trying to find dyno comparisons.
Old Mar 5, 2011 | 06:20 AM
Turbo-LS's Avatar
OP - What turbo and manifold is being run on this setup?
Old Mar 5, 2011 | 03:54 PM
1fastlude1's Avatar
its a mini ram horn and t3t04e im not looking to make huge power just adding cams i just want better mid and high power, it put down 430whp and 300wtq when i had it tuned i am going to up the boost when i get cams and i know i can make 700 with oe but i want to be able to get more power with less boost and i just dont know what cam to go with i dont want to waste money on the bc cam and not get anything out of it
Old Mar 5, 2011 | 08:19 PM
Turbo-LS's Avatar
Well the skunk2 pros are to muh cam for that turbo. You can run tuner 1's
Old Mar 6, 2011 | 04:11 PM
TheShodan's Avatar
Moderator
Or GS-Rs. no need for those big things on the standard stuff
Old Mar 6, 2011 | 04:23 PM
jnv255's Avatar
It's an H series.
Stay with stock cams using that turbo, use it somewhere else
dommyy13
Oct 26, 2012 11:05 AM
phaphon
May 21, 2010 02:17 AM
Scubster
16
Apr 22, 2007 08:45 AM
Forrest Gump 9
Mar 27, 2006 12:42 PM
Hybrid96EK
Dec 2, 2003 10:12 AM
