need help installing turbo on b16a1
Old Feb 28, 2011 | 02:54 PM
solo2fresh's Avatar
Default need help installing turbo on b16a1
just wondering where do i collect the oil line at? do i drill a hole on me oil panel for out let or inlet. i dont get the how it is. i nneed some tips plz.
Old Feb 28, 2011 | 03:08 PM
94GSRMR's Avatar
Default Re: need help installing turbo on b16a1
1 oil line goes to the back of the block the other goes to oil pan ...
Old Feb 28, 2011 | 03:11 PM
solo2fresh's Avatar
which one goes to the Pan?
Old Mar 1, 2011 | 04:53 AM
BigMike0147's Avatar
Oil return line feeds back into the pan. It's gravity fed so don't have any "uphill" spots
Old Mar 1, 2011 | 07:27 AM
dpetro1's Avatar
the oil feed needs to be a pressurized source. you can either tap into the oil pressure sender or use a sandwich adapter on the oil filter. -3 or -4 AN is the typical size.
the return line drains into the oil pan. the line should be at least -10AN and high on the pan. as mentioned above its gravity fed so you want a nice downward slope.
you can easily get a kit from someone like B&R Fittings https://honda-tech.com/forums/forced-induction-49/turbo-oil-feed-return-kits-oil-restrictors-2239281/
Old Mar 1, 2011 | 11:52 AM
solo2fresh's Avatar
thanks yall. where is the oil pressure send locates at?
Old Mar 1, 2011 | 11:53 AM
solo2fresh's Avatar
it would be good if i theres a diagram and turbo setups. would make it easy to install a turbo.
Old Mar 1, 2011 | 01:14 PM
MR.johnson's Avatar
its on the back of the block. its a 1 wire pressure sensor.
Old Mar 2, 2011 | 03:39 AM
dpetro1's Avatar
Old Mar 2, 2011 | 03:48 PM
solo2fresh's Avatar
nice just wat I need. Thanks dude.
Old Mar 2, 2011 | 04:09 PM
94GSRMR's Avatar
good luck
94GSRMR's Avatar
prime the oil pump before you start it up
jprelude92
Aug 30, 2008 07:12 AM
killamike0001
Sep 6, 2007 12:22 PM
iperez
Jan 18, 2003 04:36 PM
GruvyTune
Nov 18, 2001 03:59 PM
Peter K
Aug 29, 2001 09:58 PM
