crank, rods and pistons
Old Mar 6, 2011 | 03:55 PM
94civicgsr's Avatar
Default crank, rods and pistons
i have a 97 gsr block and was going to sleeve it for 84 mm. question here is what crank rods and pistons do i need to make it a 2.0. when i research at eagle they have 3 different sizes for crank and rods. i was told ls/b20 but want specs of the ones i need. other question is do i use ls pistons or gsr pistons.
Old Mar 6, 2011 | 06:31 PM
AllShowNoGo727's Avatar
Default Re: crank, rods and pistons
I wouldnt put stock pistons in a sleeved block, if im spending the bread to sleeve a block, Im going to use forged pistons and rods. Pretty sure to get a true 2.0 youll need to use an LS crank, and rods that were designed to be used with an LS crank. LS crank, you use LS rods. GSR crank, you use GSR rods.
Old Mar 6, 2011 | 06:39 PM
TheShodan's Avatar
Moderator
For true 2.0 Litre, B20 or LS Crank (with B20 or LS Rods), they are the same length. But this is only if going to sleeve to 84mm
Old Mar 6, 2011 | 07:10 PM
94civicgsr's Avatar
So on the forged pistons are the wrist pins in the same location for a ls and Gsr preferably talking about cp 84 mm 9.7:1
Old Mar 6, 2011 | 08:00 PM
94civicgsr's Avatar
So is the Gsr stroke 3.4330 and rod length 5.430 and for the ls it's 3.5040 and 5.394
1991islsv
Nov 21, 2008 07:25 PM
TurboEH2
Apr 2, 2005 11:15 AM
svmnredracr
Sep 28, 2004 07:46 AM
1.8T_EG
Mar 27, 2003 06:36 PM
