will this jerry rig work
Old Feb 16, 2011 | 05:03 PM
abusedvtec's Avatar
Default will this jerry rig work
i have one of these boost controllers off ebay came with the kit but the **** fell out and i only have the adj portion of it i went to hardware store and bought a spring and ball bearing and a bolt that fit in it i have the port closest to the **** to my compressor housing and the other to the bottom port on my wastegate is this correct or am i mixing up the two mbc styles i installed it and hit 9.9psi and hit boost cut
Old Feb 16, 2011 | 08:24 PM
TheShodan's Avatar
Moderator
Default Re: will this jerry rig work
I wouldn't trust it, but hey, its up to you.
Old Feb 16, 2011 | 08:44 PM
ke98248's Avatar
If you have an external wastegate, just run a different spring to reliably run more boost, and ditch that crap.
Old Feb 17, 2011 | 04:08 AM
spoolinlude's Avatar
I live under a rock
Agreed, that thing is junk. Just run off the wastegate, until you can get a decent controller.
Old Feb 17, 2011 | 10:01 AM
W!d3b0dYr3X's Avatar
Switch to an electronic boost controller. Much safer and alot more accurate
AZNracerx1989
Jul 18, 2005 10:12 AM
SoSlo
May 18, 2005 11:12 AM
vtec.dc2
Dec 28, 2002 08:03 AM
The Punisher
Jun 21, 2002 09:57 AM
