New LS turbo problem
Old Mar 9, 2011 | 08:12 AM
spoon93's Avatar
Default New LS turbo problem
Ok so car has been sitting for a while I took it out lastnite for a lil spin got on it through 1st 2nd and wen I hit third I heard a little pop so pulled in my garages And seen one Intercooler pipe popped off then opened the hood and there was oil on top of my vc long story short I pulled the plug wire from cylinder 4 and it wAs filled with oil to where I couldn't see the plug same with 2 and 3 but not nearly as bad the car seemed like it was runnin fine at idle and all could this jus be the gromets idk lmk what you guys think there was a little oil on the bottom of the plug but other than that plugs look new
Old Mar 9, 2011 | 09:23 AM
spoon93's Avatar
Default Re: New LS turbo problem
Ideas?
Old Mar 9, 2011 | 10:57 AM
LightningTeg's Avatar
Community Builder
Use periods. Could be moving oil past gaskets from crankcase pressure. Before my catch can on my stock LS I would leak oil like mad from the VC gaskets.
Old Mar 9, 2011 | 11:11 AM
spoon93's Avatar
Ok so I should replace gaskets an get oil catch can or do I have to get extra fittings on my vc
Old Mar 9, 2011 | 01:46 PM
spoon93's Avatar
Ttt
Old Mar 9, 2011 | 01:58 PM
b00stME's Avatar
If your car doesn't smoke out the exhaust, then most likely it's the valve cover gasket Is leaking oil into the spark plugs
Old Mar 9, 2011 | 02:05 PM
jubbeng's Avatar
check those round valve cover gasket that goes over the spark plug hole
Old Mar 9, 2011 | 07:39 PM
spoon93's Avatar
I did there jus covered in oil there pretty new but I think I made a mistake of putting gasket sealer on the gaskets when I first put them on. If right I beleve ur not supposed to use the sealer on new gaskets?
Old Mar 9, 2011 | 07:45 PM
Community Builder
Ive used RTV almost everytime
Old Mar 10, 2011 | 06:42 AM
spoon93's Avatar
Wat gasket you use oem the one I got was from autozone it was orange
Old Mar 10, 2011 | 07:52 AM
spoon93's Avatar
Lightning teg anoTher Ques did you have ur valve cover vented on ur ls turbo if so you think that's possibly my prob
Old Mar 10, 2011 | 08:53 AM
93ls10.0's Avatar
my ls had the same prob put two 1/2" npt vents off it to catch can not one problem since
Old Mar 10, 2011 | 09:13 AM
spoon93's Avatar
Nice do you have any pics by chance?
Old Mar 10, 2011 | 09:50 AM
Community Builder
Yeah I did. If you have an OBD2 block (which has almost nothing for a PCV system vs the older blocks) you may need a catch can for higher boost.
Old Mar 10, 2011 | 10:11 AM
spoon93's Avatar
Looks nice bro. And ya I have a 94 ls swap in there so guess I gotta figure out how to vent my vc huh
Old Mar 10, 2011 | 10:53 AM
cleansi's Avatar
if your going to vent the valve cover you should just go ahead and vent the back of the block heres a link to some fittings for b series. dont know what block you have. just get a quart size breather and your good to go..
there are also a lot of threads on how to diy.
i always use a little rtv....
http://www.xenocron.com/bseries-brea...kit-p-577.html
Old Mar 16, 2011 | 07:35 AM
spoon93's Avatar
UpDate!! Ok so I vented the valve cover, put a new valve cover gasket and o ring set on. Took it out for a drive , got home and cylinder number 4 had a little oil again in it, it was just a little bit but I could definitely see it. Could thi jus be leftove oilleasking outta plug wires or something any ideas are much appreciated thanks ht
Old Mar 16, 2011 | 07:36 AM
spoon93's Avatar
Default Re: New LS turbo problem !!UPDATE!!
Ttt
Old Mar 16, 2011 | 07:49 AM
intense4thgen's Avatar
very possible its left over if you never cleaned out the plug wire ends
Old Mar 16, 2011 | 07:51 AM
spoon93's Avatar
Hope so. If not what other possible problems?
cjwang2
Sep 30, 2015 10:17 AM
teggyteg33
Mar 12, 2013 09:52 AM
95accordex1
Jul 4, 2008 10:41 AM
the.hamburglar
May 22, 2006 10:18 PM
brixity
Jul 28, 2005 03:20 AM
