zex wet kit with only meth input?
Old Mar 8, 2011 | 01:07 PM
redlsvtec4door's Avatar
Default zex wet kit with only meth input?
I have a stock 97 hx used for commuting.
I also have a zex wot switch wet kit and a cooling mist water meth kit in my shed and over 30 gallons of high grade methanol.
My question is I would like to run 80-100 shot on a stock motor with meth running directly into the feed for the "fuel" part of the nitrous system. I will have the pump and nitrous on a toggle switch so the pump will have instant pressure when the nitrous comes on.
My question is if gasoline takes 14.7/1 for the perfect mixture and methanol takes down in the 6's to 1 about what size jet should I run for the fuel. Also the pump is a 150psi pump which needs to be taken into account, not the usual 40-50 psi efi system pressure. Also this is a 100% meth system, no water added.
does anyone know of a jet catculator that uses on meth as the fuel and 150 psi pressure?
LiL JoN
Feb 17, 2006 07:02 PM
ozzyman
May 28, 2004 10:21 PM
tegon-gsr
Dec 8, 2003 01:07 PM
Chris_
May 19, 2003 12:20 PM
b18c-93
Nov 27, 2001 12:01 PM
