Valvetrain - Spring Valve Cam Recommendation
Old Feb 21, 2011 | 09:04 AM
Muckman's Avatar
Moderator in Chief
Icon2 Valvetrain - Spring Valve Cam Recommendation
I bent a valve from an overrev/overboost incident while tuning my EBC. Right now I have an unported GSR head with ITR valvetrain (springs/valves/retainers/cams). Im thinking if I have to remove the head to replace valves I might as well upgrade them.
Im thining of upgrading to Skunk2 Pro 1 cams too. What spring ratings are recommended for the Pro1 cams? Should I upgrade the valves too or replace with ITR again? Are Pro1 cams even a good choice for an unported head? I dont want to rev higher than 8500 and Im making about 500hp now.
Here is my complete setup:
Muckman's 500hp Integra Hytech GT30R
Old Feb 21, 2011 | 09:36 AM
tepid1's Avatar
Default Re: Valvetrain - Spring Valve Cam Recommendation
Ferrea S10032 and E11000 are perfect for what you are looking to do with your Pro 1's.
I have a full set if your interested, used less than 6hrs and they were used with CTR's (00-01 ITR) cams.
Those are the OEM seat locators in the container as well.
Old Feb 22, 2011 | 06:33 AM
Muckman's Avatar
Moderator in Chief
What is the min recommended seat pressure for Pro1? 80lbs?
What do you recommend for valves?
Old Feb 22, 2011 | 07:57 AM
tepid1's Avatar
Not sure on the seat pressure. A min of 80 sounds about right....
The ferrea valves work great as well. It's a bit more money than some of the competitors, but numerous people seem to prefer them over the others.
Old Feb 23, 2011 | 02:25 PM
Muckman's Avatar
Moderator in Chief
Which Ferrea valves do you recommend? the 6000 or Competition Plus series?
Old Feb 23, 2011 | 03:40 PM
96 GSR-T's Avatar
At your power level and rpm range there is no need to drop the extra coin on Ferrea stuff, just my .02
Old Feb 24, 2011 | 03:06 PM
Muckman's Avatar
Moderator in Chief
I bent a valve so I might as well upgrade. Id like to see 600 this summer and want a valve train to support Pro1 cams.
Old Feb 24, 2011 | 04:28 PM
kyden's Avatar
on the 30r? i wouldn't do pro1's.
Old Feb 25, 2011 | 08:52 AM
tepid1's Avatar
I forget which ones I have in my head, but if I remember correctly it was the comp valves.
While you're spending the money what's a few dollars more?
Old Feb 25, 2011 | 01:19 PM
96 GSR-T's Avatar
You don't have enough turbo for those cams.... just sayin.
I doubt he needs anything over 65lb seat pressure for what he is trying to do and more, no sense on losing power with extra seat pressure his engine doesn't need. I see plenty of people reving the ish out of Supertech stuff making big power.
I ran the S10035 (65lb) and .5mm OS Super Alloy's at 10k and around 600hp without an issue, I have the full set for sale as well... I need the 95lb stuff anyway but I am also considering a roller setup or I would reuse the stuff.
crxb16a90
Jan 6, 2010 08:04 AM
GReddy SI
17
Nov 8, 2009 12:51 AM
killerB16A
Oct 13, 2009 10:08 AM
- LoL - db8
Jul 5, 2005 10:02 AM
ninjaman
Jul 17, 2001 12:55 PM
