Blown turbo help!?
Old Feb 19, 2011 | 02:12 PM
hondaB's Avatar
Icon3 Blown turbo help!?
I have a 2000 civic with a b18 swap on boost. Set up is a turbonetics t3/t4.. Im still producing boost like normal but i blow smoke out of my exhaust and i have a little side to side play but no up and down and the turbine wheel spins and doesn't hit the housing.. There shouldn't be any play or smoke at all but i still am making boost im lost..
Old Feb 19, 2011 | 02:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Blown turbo help!?
What color smoke? Are the seals blown on the turbo? Are you running a restrictor?
Old Feb 19, 2011 | 02:23 PM
hondaB's Avatar
its white smoke... i have a 3" pipe all the way back catless so im not sure if thats part of it.. Im pretty sure the seals arent but then again im not sure.. Restrictor im not sure bought it boosted
Old Feb 19, 2011 | 02:49 PM
TheCivicMafia's Avatar
If your seals arnt leaking on the turbo
then sounds like you got blow by or a bad valve seal
Old Feb 19, 2011 | 03:04 PM
sde780's Avatar
everyone with an ebay turbo who runs a restrictor says theirs lasts a decent amount of time. I assume you should run one too
Old Feb 19, 2011 | 03:25 PM
hondaB's Avatar
How do i check the seals? and whats blow by? But what about the little bit of shaft play?
Old Feb 19, 2011 | 03:26 PM
hondaB's Avatar
Mines not an ebay turbo
Old Feb 19, 2011 | 03:47 PM
The Grumpiest
Possibly you are getting headlift. Do you know if ARPs are installed?
Old Feb 19, 2011 | 04:03 PM
hondaB's Avatar
supposedly they are i haven't pulled the valve cover yet lol
Old Feb 19, 2011 | 04:29 PM
How much boost you running on what mods
Old Feb 19, 2011 | 05:00 PM
hondaB's Avatar
It's tuned on 15 but I never hit it most I hit is 7 untill I get better clamps. Built and sleeved bottom end stock head
Old Feb 23, 2011 | 08:52 AM
hondaB's Avatar
any ideas? dosent seem to smoke really that much maybe a retune?
Old Feb 23, 2011 | 09:02 AM
SovXietday's Avatar
The only smoke a retune fixes is black smoke. (running too rich).
Look at your coldside IC pipes right after the turbo, if they have oil in them that's your problem. If they don't, compression and leakdown test.
hondaEg_808
Jun 11, 2010 10:38 AM
TnC
Mar 30, 2008 01:57 PM
huntsturbocivic
Apr 22, 2007 05:17 PM
iwhichisme
Apr 18, 2004 01:28 PM
jaymes2030
Jan 17, 2004 08:20 PM
