bosch. fuel pump
Old Feb 24, 2011 | 10:13 AM
chippinpressure's Avatar
Default bosch. fuel pump
Ive done some research and can't find my answer.does it matter if the inline bosch pump is mounted under car near tank or up front inengine bay.would it stress the intank walbro if I put to close to tank.my plans were to put it under car near tank.thanks
Old Feb 24, 2011 | 11:36 AM
darkvader0's Avatar
Default Re: bosch. fuel pump
Have had mine under the car for many years now. Real nice spot down there to put it and easy to do/reliable.
Old Feb 24, 2011 | 03:28 PM
do u have the walbro (or similar) intank also?
Old Feb 24, 2011 | 06:34 PM
darkvader0's Avatar
I sure do. Walbro 255 in the tank feeding the Bosch. It is mounted to the bottom of the car by wrapping a piece of sheet aluminum around the whole pump and a thin peice of rubber between the aluminum and the pump. The aluminum is doubled over and secured to the bottom of the car using a few sheet metal screws.
I had a big gauge stereo amp. wire going to the back so I tapped that and power the pump using a relay that is switched on when the stock pump gets power.
Old Feb 26, 2011 | 06:26 PM
Thanks for the help just finished up the fuel system everything came out great
heyitzspikey
Mar 4, 2007 02:46 PM
EMFinite
Aug 10, 2006 05:47 AM
1genmud
11
Mar 28, 2003 03:23 AM
recall
May 5, 2002 04:11 PM
veejay
Jul 22, 2001 10:57 AM
