advice on hooking up my catch can
Old Feb 17, 2011 | 10:24 PM
boostedBLUfg2's Avatar
Default advice on hooking up my catch can
hey guys,
i've been running my catch can on my 07 turbo si for about 5k miles now. i just took it out tonight and there wasn't a drop of oil in it.
i have a hose running from the vc to the can, and a hose from the pcv valve to the can. i also have the can full of scotchbrite pads, so it should be catching stuff.
someone told me i need to drill out my pcv valve since it closes under boost and is effectively doing nothing to help drain into my cc. is this true? i'm a little hesistant to drill out a valve. i have minimal knowledge on what it does, but i'm hesititant to drill out something engineered to this car.
thanks
Old Feb 17, 2011 | 10:41 PM
JDMAF's Avatar
Default Re: advice on hooking up my catch can
it will close under boost... it only will open under vacuume thats why its hooked up to the intake manifold... to suck out the gases in the crankcase... so you need to hook that back up... is the catch can vented??? or is it a sealed catch can???
Old Feb 17, 2011 | 10:54 PM
sealed cc
Old Feb 17, 2011 | 11:16 PM
JDMAF's Avatar
needs to be vented... here is a thread on the idea of a vented valve cover lots of good stuff..
https://honda-tech.com/forums/showth...ed+valve+cover
here is a page of go autoworks of what a vented oil catch looks like... you can do it however you want but gives a good idea of what one looks like...
http://www.go-autoworks-store.com/gogtoilcacan.html
Old Feb 18, 2011 | 12:38 AM
racebum's Avatar
wow, this is bad news, you have effectively created a non venting system. **** like this is what blows seals. crankcase pressure has no where to go. if you do a sealed system it HAS to pull suction from your airfilter tube. if you don't do this you have to run a vented system. as it sits now crankcase pressure has no where to go
Old Feb 18, 2011 | 12:27 PM
Ls_dx's Avatar
yes. vent your cc
Old Feb 21, 2011 | 08:28 PM
guess I won't be going back to that shop.. luckily I haven't been boosting lately (got a new kit, so it's NA at the moment). should I drill out the pcv then?
Blue94Accord
Apr 19, 2012 08:01 PM
x91civichatch
Nov 14, 2005 03:21 PM
igo4bmx
Aug 18, 2004 06:55 AM
Ls-Rturbo
May 7, 2004 06:37 PM
fiebru1119
Feb 19, 2002 05:34 AM
