HELP huge boost problem
Old Feb 20, 2011 | 08:03 PM
PNK SLP's Avatar
Default HELP huge boost problem
Hey guys.
OK first off I want to say I still have my throttle body/tps issue. OK now I went to go start my car and went for a drive since i sat all winter. I let the car warm up for 30min. And i took it on a nice slow drive for about 20mins. I wanted to feel that boost so I went on the highway and I hit boost took her to around 7K and then when I went in to 4th gear its like I hit a brick wall. I lost all boost. My gauge will read from 20vacuum to 0 but nothing past that. I cant even hear my turbo spool anymore. My motor sounds good, no ticks or anything just not spooling. At idle I can see that the turbo fins are still spinning. Im not smoking or anything. As of now its back into storage but would anyone have any idea what it could be?
The only thing I came up with was, vacuum leak, BOV or wastgate is messed up?
Thanks guys, just sucks after it sits all winter it does this with no warning.
-ben-
Old Feb 20, 2011 | 08:17 PM
TheShodan's Avatar
Moderator
Default Re: HELP huge boost problem
check I/C piping for disconnections or tears. If you're only reaching vacuum, chances are you just have something disconnected.
Old Feb 20, 2011 | 08:21 PM
PNK SLP's Avatar
Ok thats odd that would happen I have had the car for almost 4 years and never had that issue. I will look into that tomorrow. I hope that's all it is,
Even if that was the issue wouldnt you still be able to hear the turbo spool?
Old Feb 20, 2011 | 08:24 PM
wantboost's Avatar
Who is Mr Robot?
from motor movement, heat cycles and vibrations you more than likely tore a coupler.. its more common than you think.
Old Feb 21, 2011 | 09:56 PM
PNK SLP's Avatar
Yep i blew the charge pipe off the FMIC. Thanks guys.
Ultra EK9
Feb 13, 2011 06:48 AM
90AcuraIntegra04
Feb 4, 2006 11:25 AM
95civ
Aug 19, 2005 06:05 AM
DIRep972
Dec 4, 2001 05:11 AM
