Return Line Size for SC61
Old Feb 15, 2011 | 09:16 AM
be18see1's Avatar
Default Return Line Size for SC61
Just started putting together all of my lines/fittings/etc for my turbo setup and realized that I have -8AN line (1/2") for my oil return. I know typically guys run -10AN lines (5/8") for the return. Will I be alright?
Old Feb 15, 2011 | 09:23 AM
kyden's Avatar
Default Re: Return Line Size for SC61
get -10.
Old Feb 15, 2011 | 12:22 PM
be18see1's Avatar
ughhhhhhhhhhhhhhhhhhhhhh
Old Feb 15, 2011 | 01:09 PM
Muckman's Avatar
Moderator in Chief
I think you would be ok with -8. Make sure the return angle is perfect. It has to always slope down hill, the steeper the grade the better. And the bung on the pan should be as high as it possibly can be.
Old Feb 15, 2011 | 01:14 PM
Turbo-LS's Avatar
when gravity draining bigger is better, you need to run a -10an on a journal bearing even if running an oil restrictor, -8an is fine on gt/ball bearing turbos due to alot less oil volume
Old Feb 15, 2011 | 01:46 PM
be18see1's Avatar
it's a journal bearing turbo with a straight down drain and obviously a gradual curve into my oil pan, which is tapped with a 1/2" npt fitting. this sucks. now i have to buy new lines and weld another bung ti my pan. fuuuuuuuuu. thanks though guys.
Old Feb 15, 2011 | 02:35 PM
wantboost's Avatar
Who is Mr Robot?
If you have a threaded bung on your oil pan, just buy a 1/2npt-10am adapter. Dot need to have the whole oil pan redone
Old Feb 15, 2011 | 03:38 PM
be18see1's Avatar
well then what's the point of having 5/8" line with a 1/2" port? makes no sense.
Old Feb 15, 2011 | 04:16 PM
wantboost's Avatar
Who is Mr Robot?
Lol good point
Old Feb 15, 2011 | 04:17 PM
LightningTeg's Avatar
Community Builder
Doesnt matter. As long as the drain is correctly oriented.
I dont think the cartridge is any different then most T3/T4's.
Old Feb 15, 2011 | 07:29 PM
be18see1's Avatar
so we're at a 40/60 or so. i had read that 1/2"+ is fine but you can't believe everything you read haha
Old Feb 15, 2011 | 08:14 PM
luck4rmkc's Avatar
I run a -8AN return on my SC61...
But then mine does smoke a little on decel... I don't think that is really due to the return line size as much as it needing some new seals. I was going ot try to switch to a restrictor fitting on my oil inlet before I bit the bullet on a rebuild cuz it doesn't smoke all the time.
Old Feb 15, 2011 | 08:37 PM
siblues's Avatar
I am running a -10an on my sc61 and still have smoking issues and my return line couldnt be and steeper going into the pan.I would suggest -10an but there are much smarter people on here than me.
Old Feb 15, 2011 | 09:02 PM
$amGD3's Avatar
Swaggylicious
Smoking issues? Can you give more details?
I just finished my setup too and redid my return line and I still have smoke.
What size feed line is everyone using? I'm on -4an with no restrictor
Old Feb 15, 2011 | 10:21 PM
Community Builder
Id run a -3 on that turbo.
Old Feb 16, 2011 | 02:46 AM
be18see1's Avatar
i have a -4 feed line that i'll run a restrictor on.
Old Feb 16, 2011 | 04:17 AM
Turbo-LS's Avatar
should run a restrictor on all turbos unless otherwise stated by turbo manufacture aka borg warner turbos
Old Feb 16, 2011 | 06:15 AM
be18see1's Avatar
yeah i plan on running one.
MalcolmV8
Dec 5, 2011 05:29 PM
Luis Valdez
Honda Civic (2006 - 2015)
Feb 8, 2009 06:03 PM
CTR_B
Apr 15, 2008 11:00 AM
toolowsol
Feb 9, 2006 01:52 PM
b00stedsi
Jul 28, 2002 04:17 PM
