98 honda civic ex turbo
Hey everyone im trying to figure out if my motor can handle a small boost
its a d16y7 i am only trying to run like 4 psi right now if i can handle more let me know its all stock this is what i have so far for the turbo setup
1.Turbo
2.Turbo Manifold
3.Blow off vavle
4.Fuel regilator
5.intercooler (w/ all piping needed)
6.Larger Oil pan ( getting oil return/feed kit)
7.WasteGate
8.boost controler
9.getting vacuum manifold
also if someone can explain how the vacuum lines work and were they go please let me know thanks
1.Turbo
2.Turbo Manifold
3.Blow off vavle
4.Fuel regilator
7.WasteGate
8.boost controler
Re: 98 honda civic ex turbo
instead of being lazy, howabout you look through some articles. These questions been answered time and time again. why do we need to go through and reinvent the wheel?
If your car is really an EX then you have a y8 not a y7. Either way, psi is arbitrary, and yes your motor can handle boost. 200 whp should be fine with a good tune.
1.Turbo Good, yeah you need that
2.Turbo Manifold Yep
3.Blow off valve Yep
4.Fuel regulator Unnecessary
5.intercooler (w/ all piping needed) Yep
6.Larger Oil pan ( getting oil return/feed kit) Totally unnecessary, stock oil pan is fine
7.WasteGate Stick with an internal WG for your first setup
8.boost controler Yep, manual ones can be had on ebay for <$10
9.getting vacuum manifold A vacuum manifold? Just T lines off your intake manifold for vacuum sources
This isn't the end of your list, and I'm being awfully generous for answering your questions without pointing you to the search button. You're going to need an EMS, those can be had for cheap too but it sounds like what you really need is to read the FAQ. People have been boosting Hondas for 20 years. This isn't new.
Hey my turbo is water cooled and I check the FAQ didn't find anything about it but can I just plugnthe holes a run just the oil or do I have to water cool it and also I will only be running 3 psi right now
Briman2021
09-10-2002 10:00 AM
