7.5:1 to 10:1 compression noticable performance difference?
Old Feb 22, 2011 | 05:05 AM
wtsapexipowerfc's Avatar
Default 7.5:1 to 10:1 compression noticable performance difference?
Just wanted to get some insight regards to the main noticeable differences in performance if I went from my vitara pistons to a set of SRP 10:1 compression pistons. My current comp ratio is in the neighborhood of about 7:1 to 7.5:1, I believe.
Here is my current dyno graph with the low comp set up..
I currently get full boost by about 3800 - 4200 rpms (13.5psi)
http://img51.imageshack.us/f/dynochart.png/
Car set up
go autoworks street kit
T3 50 trim turbo NOT a t3/t4
3" exhaust
2.5" dp (should have gone 3", but worried that it would be to loud)
3 layer metal head gasket
Old Feb 22, 2011 | 06:25 AM
Stopsign32v's Avatar
Loved
Default Re: 7.5:1 to 10:1 compression noticable performance difference?
Lol serious? It's night and day! Why on earth do you only have 7.5:1
Old Feb 22, 2011 | 06:29 AM
vitara pistons.. there cheap
Old Feb 22, 2011 | 06:32 AM
ref1590's Avatar
huge difference..if you want to run high boost lower compression is best. all motor higher compression.
Old Feb 22, 2011 | 06:47 AM
Ryank327's Avatar
Vaguely correct. But with the technology and skilled tuners today you can run 11:1 and get 450 whp with no problems
Old Feb 22, 2011 | 06:57 AM
TheShodan's Avatar
Moderator
Read Tony the Tiger's comments in the middle of page 3 regarding compression
https://honda-tech.com/forums/showth...2898882&page=3
99siRACER
Jan 3, 2012 12:20 AM
ekhatchb18
Aug 7, 2008 10:50 PM
madcrossover
Dec 13, 2004 06:40 AM
thinkbrianthink bu
Oct 13, 2002 10:47 AM
DrPhang
Apr 30, 2002 04:12 AM
