map sensor b-series
Old Feb 18, 2011 | 07:29 AM
krugozor's Avatar
Default map sensor b-series
hello again misters.
could u please tell me about my map.
i bought a b16a2 and swap it.
installed map-sensor kod is 0798003000 5v rs-30
is it my stock map or is it pre-owner installed from prelude or etc?
and what my stock map is?
Old Feb 18, 2011 | 10:16 AM
dpetro1's Avatar
Default Re: map sensor b-series
that is the stock map sensor.
Old Feb 18, 2011 | 10:53 PM
hybrid1990crx's Avatar
stock sensor. good till about 7-8 psi.
Old Feb 18, 2011 | 11:24 PM
racebum's Avatar
i thought they read till 11?
Old Feb 18, 2011 | 11:30 PM
wantboost's Avatar
Who is Mr Robot?
11psi
Old Feb 20, 2011 | 10:08 PM
krugozor's Avatar
psi -u mean pressure for boost it?
Old Feb 20, 2011 | 10:52 PM
cleansi's Avatar
yes he means boost pressure. the oem map sensor reads to 11.6 pounds per square inch
Old Feb 21, 2011 | 05:57 AM
sixfourkiller's Avatar
actually your stock honda map is an 1.7 bar map sensor and which mean it used one bar which is 14.7 to read your vacuum pressure and the 0.7 to read if has any extra boost so it can see about 7-9 pound but its not suppose to read boost so it differents between between map sensor on how much it can actually read since it was NOT made to see boost.
and how much boost are u trying to run
Old Feb 21, 2011 | 08:38 PM
dpetro1's Avatar
the stock map sensor can read boost just fine. its a 0-5v sensor, which reads a max of about 4.78v. this works out to about 10.2-10.7 psi depending on altitude. different sensors may vary slightly but not much
the stock ecu, on the other hand, is not mapped for positive pressure. thats why you will get a CEL if you try to boost on a stock ecu.
h23aAccord
Mar 25, 2017 04:53 AM
Ldo
Oct 9, 2010 03:35 PM
hatchBK4life
Feb 3, 2010 12:08 PM
teddy_dc2
Aug 8, 2006 07:51 PM
B16Civic93
Apr 2, 2005 09:39 AM
