Noob questions, OK a few questions, need help to ID this!
Hi, this is my first post and without wanting to sound or look like a complete noob, I have a few questions if I may.
I know I should probably use the search feature, but I dont own a Honda yet and the answers to my next few questions will probably make my mind up to get one or not.
I wont bore you with my background story, otherwise we'd be here all night LOL. Anyway I went and had a look at a Civic today, I've never owned a Honda before and it had this engine in it. I think its a B16, its been turbo'd with a garret turbo, big intercooler, BOV, wastegate, 440cc injectors and a 3 bar map senser. Heres a pic.
Now, the guy who is selling it tells me its running 7psi of boost on a stock motor and claims its a common thing to do with these motors, my experiance with forced induction is to lower the CR!
So, is it safe to do this? if so what sort of power should I expect from a set up like this?
Thanks in advance, Jez
Re: Noob questions, OK a few questions, need help to ID this!
You dont always have to lower CR when boosting. Lowering it does help but with a good tuner, its not necessary.
People turbocharge stock motors all the time, whether or not it is safe is up to the components and the tune.
The only way to be sure on what kind of power it is making is to put it on a dyno.
If I were going to buy a car that was already turbocharged, the first thing I would do is get it tuned by someone I trust.
Yes, getting it tuned would be one of my first jobs if I buy it.
Obviously I dont know the motors history, but all the bits that have been added are good quality parts. I was just looking for some kind of ball park figure on power, the guy thats selling it is a dealer and has no clue!
7psi means the car has probly been running off the gate only for boost
ide get a leak down done on it
ide deffinately get a compression check done before i shelled some money out for it
Yes it is a running car, well alledgedly LOL, it was -20c here today so as of yet I have not seen it running, hopefully going back to see it again next week.
What sort of PSI should I look for on a healthy B16? if thats what it is?
Sorry for the questions but I dont want to part with any of my hard earned cash until I find out the answers.
I presume by leak down test you mean test the boost side of things for leaks?
i ran 28psi on a stock block man made 500+ out it
leak down means filling the individual cylinders with oil then going back to see whats leaks down the mist and by how much
If this is your first honda, then Id honestly pass on this car. You dont know the history, or whats really been done to it. Just asking for problems by buying it.
Unless youre honestly getting a steal of a deal..
Depends what you call a steal of a deal I guess, its for sure on stock internals and surely I'd not be the first person to buy something like this as my first Honda?
most of us buy honda's then boost them lol that way we know and understand what we have a little more
I just dont like the idea of buying a boosted car with a history that I dont know about.
I bought my car with a few mods on it already, but I got it from a friend of mine who used to own it. I trust him, and it came with a booklet of reciepts for the modifications, so I know exactly whats been done to it.
If you do want to buy the car, proceed with caution. Look over every inch of the car. Especially since its boosted, there could potentially be alot of problems with it.
I agree with everyone else.
Compression test
Leak down test
to make sure the internals are good. Check for any hoses that arent where theyre supposed to be, disconnected lines, etc.
There seems to be quite a bit done to this car, and its your first honda, thus the reason why Im saying be careful with it. But good luck anyways.
Compression test
Leak down test
Compression test
Leak down test
Compression test
Leak down test
I just came across this and thought it'd be something different, the work that has been done looks tidy and well done. I'll go back next week and see it running and get thte guy to do a comp test on it.
For what its worth the price is $5000 CDN, seems fair as the rest of the car is near mint with with some other nice goodies on it also.
Thanks
personally, i had a really bad experience with buying a pre-modded car... on paper things looked great, the engine looked great, it drove great, but 2 months later, my $7500 all motor b16a blew up due to something small (i.e- the $20 thermostat)... so be carefull and take all the advice people have been throwing at you... ask the owner about every noise, vibration, and bump the car makes
Well thanks for your input guys, I'll go back and ask some more questions if they check out I'll get a comp test done and take it for a test drive.
Where will the engine code be stamped on the block? been looking around on this site and it looks like it could be one of a few engines, be nice to know for sure what it is before I go to much further with it.
thanks
thanks
